hi,
i am new to nagiosxi i am using free version nagiosxi when i try to click nagios core configuration it asked for id password i enter my admin is password but it gave error invalid and there was option under the login screen for reseting password while my admin is pass is correct thats why i am using this application !
what id pass should i use to login inorder to use google map in nagiosxi as shown in the link below,
http://www.youtube.com/watch?v=qN20qSMga9E
Hopes for your suggestions ...
Regards,
Nagios Core Configuration Manager Login Fail ??
mohsin2011
Re: Nagios Core Configuration Manager Login Fail ??
Mohsin,
Did you ever set a password explicitly for the Core config Manager? The password the CCM is different than Nagios XI.
When you are at the CCM login screen, there is a link in the last paragraph that lets you reset your CCM credentials. Give that a try.
Nicholas Scott
