check_snmp plugin perdata output error
Hi to all,
I have strange issue when i'm using check_snmp plugin with -u option.
Nagios Core 4.1.1
Nagios plugin 2.1.1
Ubuntu 14
Command : check_snmp!-C public -o BSS-RCP-MIB::storage-load.0 -u % -c 1:100
Nagios service :
Status Information: SNMP OK - 12 %
Performance Data: BSS-RCP-MIB::storage-load.0=12;;1:100%;;100;
No RRD file created, error in perfdata format % is after the critical threshold and not after the value.
Command : check_snmp!-C public -o BSS-RCP-MIB::storage-load.0 -c 1:100
Nagios service :
Performance Data: BSS-RCP-MIB::storage-load.0=1;;1:100;;100;
RRD file created, correct perfdata output
Does someone already seen this? or better does someone have a solution.
Best regards
Sebastien
Nagios Core 4.1.1
Nagios plugin 2.1.1
Ubuntu 14
Nagios service :
Nagios service :
Best regards
Sebastien
Re: check_snmp plugin perdata output error
Can you run the check_snmp command over the CLI, and post the full command and output for us to look at?
As well, what happens if you place the % in quotes?
check_snmp!-C public -o BSS-RCP-MIB::storage-load.0 -u "%" -c 1:100
Thank you for your answer rkennedy
I'm not at my office this week, I will test this weekend.
Regards
Seb
Regards
Seb
We will keep this open until you return. Please post back only once you have additional information for us.
Hi rkennedy,
I just do the test and unfortunately I have the same result
Perfdata output with error with "%" at the wrong place
BSS-RCP-MIB::cpu-load-idle.1=87;8:100;2:100%;100;100;
It looks like a bug
Seb
check_snmp!-C public -o BSS-RCP-MIB::cpu-load-idle.1 -u "%" -w 8:100 -c 2:100BSS-RCP-MIB::cpu-load-idle.1=87;8:100;2:100%;100;100;
It looks like a bug
Seb
- Box293
- Too Basu
Can you execute these commands and post back the output:
Replace xxx.xxx.xxx.xxx with the correct IP.
./check_snmp -H xxx.xxx.xxx.xxx -C public -o BSS-RCP-MIB::storage-load.0 -u % -vCode: Select all
./check_snmp -H xxx.xxx.xxx.xxx -C public -o BSS-RCP-MIB::storage-load.0 -u % -c 1:100 -vCode: Select all
/usr/bin/snmpget -Le -t 1 -r 5 -m ALL -v 1 -c public xxx.xxx.xxx.xxx:161 BSS-RCP-MIB::storage-load.0 -D allAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
/usr/bin/snmpget -Le -t 3 -r 5 -m ALL -v 1 [authpriv] 192.168.2.100:161 BSS-RCP-MIB::storage-load.0
BSS-RCP-MIB::storage-load.0 = INTEGER: 1
SNMP OK - 1 % | BSS-RCP-MIB::storage-load.0=1%
BSS-RCP-MIB::storage-load.0 = INTEGER: 0
SNMP CRITICAL - *0* % | BSS-RCP-MIB::storage-load.0=0;;1:100%;;100;
/usr/bin/snmpget -Le -t 1 -r 5 -m ALL -v 1 -c public xxx.xxx.xxx.xxx:161 BSS-RCP-MIB::storage-load.0 -D all- Attachments
putty.log- (758.53 KiB) Downloaded 393 times
I verified that using the -u "units" option for check_snmp version 2.1.1 outputs the unit in the wrong location in the performance data.
Running the same check command using version 2.0.3 puts the unit in the correct location.
I will fill on a bug report for this.
- Box293
- Too Basu
Nice troubleshooting @tgriep.
@Seb06 as a temporary workaround you could compile plugins 2.0.3 and just copy the check_snmp binary over the 2.1.1 version to work around your issue.
