Dashboard Not Showing Data from Servers
blipani
Post by blipani »
My dashboard is not showing any data or setup hosts I went threw several things with the sales rep I did tcp dump and we see data being collected but it's not showing in the dashboard. Any help on this would be great we are considering buying the product if we can get it working.
Re: Dashboard Not Showing Data from Servers
This could be a few things, can you provide a bit more information about your environment?
- What OS are you running, as well as version?
- Is SELinux running by any chance? {icode]sestatus[/icode]
- When you refer to tcpdump and being collected, are you saying that the logs are indeed coming to NLS?
henriquez
Post by henriquez »
I'm just wondering if this have been resolved.. i just installed Nagios Log Server manually.. i think the nagios log server is receiving the data.. because when i went to the Admin Overview - i'm seeing the Documents, Primary Size, Total Size, etc.. is increasing, but nothing is showing up in the dashboard itself, i'm not sure if i setup this correctly. please send me an email if a solution have been found. thank you.
henriquez wrote:I'm just wondering if this have been resolved.. i just installed Nagios Log Server manually.. i think the nagios log server is receiving the data.. because when i went to the Admin Overview - i'm seeing the Documents, Primary Size, Total Size, etc.. is increasing, but nothing is showing up in the dashboard itself, i'm not sure if i setup this correctly. please send me an email if a solution have been found. thank you.
What version of NLS are you using, and which browser? Do you have a filter / query applied at all?
