NSClient - ERROR: Invalid return from command: check_pdh
dlukinski
Post by dlukinski »
Common "NSClient - ERROR: Invalid return from command: check_pdh" after installing 0.4.3
- IS there a workaround or should we move on to 0.4.4 ?
Thank you
hsmith
Agent Smith
Re: NSClient - ERROR: Invalid return from command: check_pdh
Post by hsmith »
Perhaps take a look at this: https://github.com/mickem/nscp/issues/44
Former Nagios Employee.
me.
dlukinski
Post by dlukinski »
hsmith wrote:Perhaps take a look at this: https://github.com/mickem/nscp/issues/44
Strangely this error had disappeared after updating Components and Wizards via admin web-interface
I see no direct correlation, yet this is only change I could think of
We run 5.2.3 ever since 5.1 OVF created by you / these updates were not included into 5.2.3 and for some reason had to be semi-manual)
It may have been how the command was formatted? We would have to see this problem in action to really diagnose it though.
Are we good to mark this thread as resolved?
dlukinski
Post by dlukinski »
rkennedy wrote:It may have been how the command was formatted? We would have to see this problem in action to really diagnose it though.
Yes please
Will do, feel free to open a new thread if you need any assistance in the future.
