check_hpjd shows warning unnesessarily
Adam
Post by Adam »
Hi all. I am new to Nagios and have a question regarding monitoring HP printers. The status of my printer is "Ready" but Nagios is showing it as a "Warning". This should not be a "Warning" but an "OK" status. How can I adjust this?
edit: using Nagios 4.0.8
rhassing
Re: check_hpjd shows warning unnesessarily
Post by rhassing »
Is it a HP jet direct card you are monitoring?
Rob Hassing
Adam
Post by Adam »
The printer is an HP Color LaserJet MFP M476nw. It is wired to the network. It does have a jet direct port open at 9100.
rhassing
Post by rhassing »
Maybe you should give another check a try?
SNMP Printer Check
check_snmp_printer
Authored by Jason Leonard
It can be found on http://exchange.nagios.org/
Rob Hassing
Thanks @rhassing.
Give those plugins a look to see if they'll work for your environment.
Can you also post the full check command that you are using with check_hpjd?
Adam
Post by Adam »
Sorry guys, but I didn't post my question correctly. The issue isn't that the plugin isn't working correctly. It is reporting the status correctly. The "Warning" is "No log handling enabled - turning on stderr logging ("Ready")". But it either isn't clearing the warning about log handling or isn't actually turning it on. I guess I should have read the entire status before I posted. I appreciate the help as it has been a long time since I dabbled in any Linux systems. By the way Nagios is running on CentOS 6. So how to I manually set up log handling?
What version of the plugin are you using? ./check_hpjd -V
Adam
Post by Adam »
check_hpjd v2.0.3 (Nagios-plugins 2.0.3)
Hmm, that is the current version.
Can you post the full syntax you are using with the result? I'd like to verify this is indeed a bug.
It can then be posted at our GitHub for nagios-plugins @ https://github.com/nagios-plugins/nagios-plugins/issues
Adam
Post by Adam »
I followed the quickstart quide for fedora so basically just edited the printer.cfg file to define the printer name and ip address as the guide stated.
      use                         generic printer
      hostname                ycolor
      alias                       ycolor
      address                  192.168.x.x
      hostgroups             network-printers
and the service definition
      use                               generis-service
      host_name                    ycolor
      service_description       Printer Status
      check_command           check_hpjd!-C public
      normal_check_interval  10
      retry_check_interval      1
