I have Nagios running and server is called nagios. If I go to http://nagios I get a blank page. Need to go to http://nagios/nagios.
Is it possible to force redirect to the nagios subfolder from the root?
This is running CoreOS
Thanks.
JR
redirect from root url?
Re: redirect from root url?
Yes, you should be able to create a file called index.php in /var/www/.
Paste the following inside of it, changing x.x.x.x to your IP or hostname of the Nagios server, and http to https as needed.
<?php
header("Location: http://x.x.x.x/nagios/");
die();
