SSL Redirection 5.2.3
mikew
Post by mikew »
I have reconfigured an XI server with 5.2.2 but now in 5.2.3 the configuration to redirect SSL is not working.
Any ideas?
Here is what I have:
Certificates built and working. The problem is in the redirection.
/etc/httpd/conf/httpd.conf
NameVirtualHost *:443
config.inc.php
set to true;
Systems settings:
Set to https://server_ip/nagiosxi/
Core Config manager set to https
/etc/httpd/conf.d/nagiosxi.conf
I have also tried this line:
Redirect permanent / https://server_ip/
This setting says too many redirections.
The setting below does not place a "/" between the IP and nagiosxi
<Directory "/usr/local/nagiosxi/html">
#  SSLRequireSSL
   Options None
   AllowOverride None
   Order allow,deny
   Allow from all
#  Order deny,allow
#  Deny from all
#  Allow from 127.0.0.1
#   AuthName "Nagios XI"
#   AuthType Basic
#   AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
#   Require valid-user
</Directory>
<VirtualHost *:443>
        SSLEngine on
        SSLCertificateFile /etc/pki/tls/certs/server.crt
        SSLCertificateKeyFile /etc/pki/tls/private/server.key
        AllowOverride All
        </Directory>
        <IfModule mod_rewrite.c>
        RewriteEngine On
        RewriteCond %{REQUEST_FILENAME} !-f
        RewriteCond %{REQUEST_FILENAME} !-d
        RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
        </IfModule>
</VirtualHost>
Alias /nagiosxi "/usr/local/nagiosxi/html"
Mike Weber
Nagios Training/Consulting
Re: SSL Redirection 5.2.3
Make, change:
to:
and restart apache. Did this help?
mikew
Post by mikew »
All that did is is end up saying too many redirections.
Mike Weber
Mike, what is the OS/architecture? Can you zip up, and PM me the "/usr/local/nagiosxi/html/config.inc.php", and "/etc/httpd/*"?
mikew
Post by mikew »
Centos 6
When on use the slash on the redirect line that I showed this is what is returned:
Too many redirects occurred trying to open “https://server_ip/nagiosxi”
Only two lines edited in http.con
ServerName JDTest:80
Only the https line was edited in config.inc.php
// force http/https
$cfg['use_https'] = true; // determines whether cron jobs and other scripts will force the use of HTTPS instead of HTTP
nagiosxi.conf I listed the complete file before. No other files edited in the conf.d directory.
Mike Weber
WillemDH
Post by WillemDH »
Fyi, as it was on my to do to configure the permanent redirect, I tried to configure it following procedure in https://assets.nagios.com/downloads/nag ... s%20XI.pdf
Seems after restarting httpd, CSS stopped working when surfing to the http link. Also when clicking on 'Access nagios XI' there suddenly is an error in the url resulting in a ERR_NAME_NOT_RESOLVED error..
The resulting url looks like this: https://nagiosservernagiosxi/
I tried this on my PR and QA. Same problem.
Also tried with
Redirect permanent / https://nagiosserver
and
Redirect permanent / https://nagiosserver/
Same result.
This is my whole config:
<VirtualHost *:80>
                #  SSLRequireSSL
                Options None
                AllowOverride None
                Order allow,deny
                Allow from all
#                Redirect permanent / https://nagiosserver
                #  Order deny,allow
                #  Deny from all
                #  AuthType Basic
        </Directory>
                RewriteEngine On
        </IfModule>
</VirtualHost>
<VirtualHost *:443>
        SSLEngine on
        SSLCertificateFile /etc/pki/tls/certs/nagiosserver_2016_sha256.crt
        #SSLCertificateFile /etc/pki/tls/certs/nagiosserver.gentgrp.gent.be.crt
        #SSLCertificateFile /etc/pki/tls/certs/ca.crt
        SSLCertificateKeyFile /etc/pki/tls/private/nagiosserver_2016_sha256.key
        #SSLCertificateKeyFile /etc/pki/tls/private/nagiosserver.key
        #SSLCertificateKeyFile /etc/pki/tls/private/ca.key
        ErrorLog  /var/log/httpd/ssl_error_log
        CustomLog /var/log/httpd/ssl_access_log combined
                AllowOverride All
        </Directory>
                RewriteEngine On
        </IfModule>
</VirtualHost>
I don't want to highjack your thread Mike, let me know if you want me to make a separate thread.
Grtz
Nagios XI 5.8.1
https://outsideit.net
ssax
Dreams In Code
Post by ssax »
I always do this a different way, from the default install in /etc/httpd/conf/httpd.conf I add this to the bottom:
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
That will handle the rewrites to SSL, then I just define my certs in /etc/httpd/conf.d/ssl.conf, restart apache, make the XI side changes, and it works.
Pro tip:
Add this to the bottom of you /etc/httpd/conf/httpd.conf to enable gzip compression to speed up page loads, ajax request, etc:
AddOutputFilterByType DEFLATE text/plain
AddOutputFilterByType DEFLATE text/html
AddOutputFilterByType DEFLATE text/xml
AddOutputFilterByType DEFLATE text/css
AddOutputFilterByType DEFLATE application/xml
AddOutputFilterByType DEFLATE application/xhtml+xml
AddOutputFilterByType DEFLATE application/rss+xml
AddOutputFilterByType DEFLATE application/javascript
AddOutputFilterByType DEFLATE application/x-javascript
WillemDH
Post by WillemDH »
Sean,
I'm not sure what Mike's opinion is on this, but imho everyone should use the same method, described in the Nagios XI SSL documentation, which does not work at this time. I prefer to keep working with the nagiosxi.conf Apache configuration file.
The official nagios XI documentation results in two issues when trying a permanent redirect.
- CSS broken when going to HTTP link without fqdn
- Misformed URL (omitted / between Nagios host and nagiosxi suffix
Grtz
Willem
Nagios XI 5.8.1
ssax
Dreams In Code
Post by ssax »
I agree, the information needs to be updated.
I'll create a task for it on Monday.
ssax
Dreams In Code
Post by ssax »
Mike, please zip up and PM me your /etc/httpd/conf/httpd.conf file and your /etc/http/conf.d directory and I'll lab it up and find you a resolution.
Thank you
