$ not escaping correctly in check_xi_mysql_database
cjwallgren
Post by cjwallgren »
We are currently evaluating Nagios XI with the intention to purchase, but we ran into the following issue when running the check_xi_mssql_database check command. Nagios should have sent
/usr/local/Nagios/libexec/check_mssql_database.py –H (our internal sql IP) –U sa –P \$ocInfo1 –T TestTable –p 1433 –logtruncs –warning 1000 –critical 30
Or
/usr/local/Nagios/libexec/check_mssql_database.py –H (our internal sql IP) –U ‘sa’ –P ‘$ocInfo1’ –T ‘TestTable’ –p 1433 –logtruncs –warning 1000 –critical 30
By putting the escape sequence \$ inside of quotes, the python script sees everything as
/usr/local/Nagios/libexec/check_mssql_database.py –H (our internal sql IP) –U sa –P \\$ocInfo1 –T TestTable –p 1433 –logtruncs –warning 1000 –critical 30
So over at the database it perceives NagiosXI as logging in with a password of \$ocInfo1 instead of a password of $ocInfo1.
It seems that NagiosXI runs its escape routine over all of the text contained in the $ARG#$ variables even though it should not do so when within single quotes.
Can you please advise? Thanks!
Re: $ not escaping correctly in check_xi_mysql_database
You can either try escaping the dollar sign with itself like so $$ or using the resource.cfg file to hold passwords with special characters:
https://assets.nagios.com/downloads/nag ... ource_file
cjwallgren
Thanks for the quick response! When we tried $$, the script just spit out \$\$.
What happens if you define a $USER#$ variable in resource.cfg and call to that?
As an example, you would add the line in resource.cfg -
$USER8$=$ocInfo1
