Hello all,
Is it possible to disable to create graphs for some services which have performance data in pnp4nagios ?
I know that, pnp automatically creates graphs for services which have performance data. I use pnp with nagios core and mod_gearman. I have 40k services, most of them have performance data, but I need graps only 30k services. I don't need 10k rrd files, xmls etc.
Thanks.
disable to create graphs for some services which...
yesilyurtav
Re: disable to create graphs for some services which...
At this point, I don't believe it's possible to limit graphing. It's an all-or-nothing sort of deal.
As this is for core, you can always create a request on our Github @ https://github.com/NagiosEnterprises/nagioscore/
yesilyurtav
Thanks rkennedy.
You're welcome, are we good to mark this thread as resolved?
