Backups
BanditBBS
Backups
Post by BanditBBS »
I finally got a NAS share mounted on both nodes that is shared and created a repo. No backups have been performed, what am I missing?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
jolson
Attack Rabbit
Re: Backups
Post by jolson »
It's likely a permissions problem. Try the following:
su - nagios
cd /mnt/backuppath
touch file
rm file
Also, note that the backup repository needs to be mounted in the same place across both servers. Hopefully the above gives you enough information to diagnose what might be wrong!
Twits Blog
BanditBBS
Re: Backups
Post by BanditBBS »
Fixed the perms and then made it run the backup and it froze up and borked up our NAS.....power cyclign the host now as once you get connected is freezes!
jolson
Attack Rabbit
Re: Backups
Post by jolson »
Yikes! Does your NAS have enough space to hold the data you're trying to backup? I don't remember your environment being gigantic by any means.
Twits Blog
