Report not poper
Sandeep_Patil
Report not poper
Post by Sandeep_Patil »
Currently are getting report of services on availability percentage.
We required actual utilization of services example as below.
1) Memory Utilization.
Min Max Avg
Server Memory 4 GB 500 MB 3.7 GB 2 GB
2) CPU Utilization.
Min Max Avg
Server Memory 2 GHz 10% 70% 60%
This details are showing in capacitive planning, but not able to export in excel.
bwallace
Re: Report not poper
Post by bwallace »
Correct, the ability to export Capacity Planning charts to Excel does not exist. I'd be happy to file a feature request for this if you like.
Sandeep_Patil
Can we generate as attached report by choosing option or by external query or any plugin available for same or any other option ?
You best bet would be to use the "Metrics" component. Go to Home->Details->Metrics and schedule the page as a report, selecting whatever metric you would like from the "Metric" drop-down menu (Disk Usage, CPU Usage, Memory Usage, etc.)
Sandeep_Patil
Checked "Metrics" component and drop down menu disk, cpu and memory usage. In this option get percentage details.
Can we get same details with time period option?
Can you clarify what you're looking for with a screenshot?
The metrics is what stores the disk, cpu, and memory usage.
