I've migrated from some static files that I was using during initial setup to hosts entered through autodiscovery. I've deleted the static files, but now all hosts that were in a static file is now 'inactive'. When I try to set one to 'active' I get a message like the one below:
Error: Could not add object property in file '/usr/local/nagios/etc/hosts/ads201.dc.farecompare.com.cfg' on line 17.
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for host 'ads201.dc.farecompare.com' (config file '/usr/local/nagios/etc/hosts/ads201.dc.farecompare.com.cfg', starting on line 16)
Duplicate entry errors after removing static files
- Box293
- Too Basu
Re: Duplicate entry errors after removing static files
Can you follow these steps please:
Go into CCM
Tools > Write Config Files
Click the Delete button
It will say "Successfully deleted all Host / Service Config Files"
Click the Write Button
It will show an output of all the files it creates
Click the Verify button
Do you get errors?
If you do, can you post the file /usr/local/nagios/etc/hosts/ads201.dc.farecompare.com.cfg
It doesn't exist in the profile you sent, because there was an error during Apply nagios reverts back to the previous configs, hence the steps above are required.
Go into CCM
Do you get errors?
