CRIT: GLOBALSTATUS nonCritical 4 /vol/vobsync is full (using or reserving 98% of space and 15% of inodes, using 98% of reserve).
can i get this nonCriticakl 4 as a Warning ?
check-netapp-ng.pl Globalstatus Warning
HelmutSchaeufele
Re: check-netapp-ng.pl Globalstatus Warning
You should be able to change your warning / critical settings for the service.
Navigate to Configure -> Core Config Manager -> ### Services -> From there, look for the configuration file related to that service and make the changes accordingly.
Is that what you're looking for?
