I tried the "make dox" and it only generate the nagios core source code documentation
May I know what is the reason Nagios Core manual source is not on github ?
Where is Naigos 4 core manual source ?
Re: Where is Naigos 4 core manual source ?
Where did you find this?nagmoto wrote:I tried the "make dox"
What else would you like to see on this page? https://github.com/NagiosEnterprises/nagioscorenagmoto wrote:May I know what is the reason Nagios Core manual source is not on github ?
Former Nagios Employee.
me.
me.
By reading "10. Documentation" at https://assets.nagios.com/downloads/nag ... tsnew.htmlnagmoto wrote:
I will defer answer for your 2nd question later once I check out html directory.
Sounds good, certainly let us know if there are any further questions.
How can I generate a PDF file from the html src tree ?bwallace wrote:Sounds good, certainly let us know if there are any further questions.
Looks the html files need to installed into a web server directory and have php module enabled to see them.
If I understand correctly, you're looking to convert the html documentation files to pdf?
There is not a way within Nagios Core to do this, you'll have to use a 3rd party utility for converting html -->pdf.
I am looking a way to read the nagios core 4 doc without out setting up a web server.bwallace wrote:If I understand correctly, you're looking to convert the html documentation files to pdf?
Also the doc in html format is the doc source, right ?
ie if one want to update the doc for nagios core 4, one need to familiar with html language.
The Core docs can be found online here: https://assets.nagios.com/downloads/nag ... n/toc.html
But if you are looking to edit that, you will need to understand HTML and save the pages to your local machine to edit them.
Please close out this thread.
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
