Issue box293 ESXI plugin and vMA Appliance
coopstudent
I followed the instructions from box293 on deploying and configuring a VMA appliance.
I've been able to get the password-less SSH configured and and test the plugin from command line on one ESXI host. Everything works without any issues, but the issue is when I try to configure the wizard;
On the Admin --> Manage Components --> Edit Setting for VMware vMA Settings Manager
I've configured the VMA server, but when I select TEST for the SSH Configuration I get the following:
There was an issue establishing an SSH session with the vMA host 192.168.0.xx!
The output is as follows:
Could not create directory '/usr/share/httpd/.ssh'.
Host key verification failed.
Please refer to the box293_check_vmware manual on how to configure this Nagios host to communicate with the vMA host.
Re: Issue box293 ESXI plugin and vMA Appliance
When testing the plugin from the command line did you "su - nagios" before testing or were you only testing as root?
- Box293
- Too Basu
Did you follow these steps as required by the vMA Settings Manager component:
In the steps below,
10.XXX.XXX.XXX = vMA host
10.ZZZ.ZZZ.ZZZ = ESX server
Try these commands and post back the results please:
The following commands will be done as the nagios user
Does this command prompt you for credentials?
If you do login or are not prompted for credentials, type exit so end the SSH session and return to the nagios host.
Does this command prompt you for credentials, what is the output?
We'll stop being the nagios user now, type exit
The following commands will be done as the apache user:
Also, provide the output from these commands:
Do these commands produce output? Don't post the output here.
We'll stop being the apache user now, type exit
Also, what version of check_by_ssh do you have?
mkdir /var/www/.ssh
cp /home/nagios/.ssh/known_hosts /var/www/.ssh/
cp /home/nagios/.ssh/id_dsa /var/www/.ssh/
setfacl -R -m u:apache:r-x /var/www/.ssh/10.XXX.XXX.XXX = vMA host
su nagiosCode: Select all
ssh [email protected]Does this command prompt you for credentials, what is the output?
/usr/local/nagios/libexec/check_by_ssh -E 1 -l vi-admin -H 10.XXX.XXX.XXX -C '~/box293_check_vmware.pl --server 10.ZZZ.ZZZ.ZZZ --version'The following commands will be done as the apache user:
su -s /bin/sh apacheCode: Select all
/usr/local/nagios/libexec/check_by_ssh -E 1 -l vi-admin -H 10.XXX.XXX.XXX -C '~/box293_check_vmware.pl --server 10.ZZZ.ZZZ.ZZZ --version'Code: Select all
ls -al /var/www/
ls -al /var/www/.ssh/Code: Select all
cat /var/www/.ssh/id_dsa
cat /var/www/.ssh/known_hostsAlso, what version of check_by_ssh do you have?
/usr/local/nagios/libexec/check_by_ssh -VAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
coopstudent
Thanks for looking into it. here are the results of all commands..
# below command did not prompt for credentials
[root@nagiosxi ~]# su nagios
[nagios@nagiosxi root]$
[nagios@nagiosxi root]$ ssh [email protected]
Welcome to SUSE Linux Enterprise Server 11 SP3 for VMware (x86_64) - Kernel \r (\l).
vi-admin@vma:~>
vi-admin@vma:~> exit
logout
Connection to 10.xxx.xxx.xxx closed.
[nagios@nagiosxi root]$ /usr/local/nagios/libexec/check_by_ssh -E 1 -l vi-admin -H 10.xxx.xxx.xxx -C '~/box293_check_vmware.pl --server 10.zzz.zzz.zzz --version'
box293_check_vmware Version: 2015-08-03
# below command did produce output
[nagios@nagiosxi root]$ ls -al /var/www/
# below command did NOT produce output
[nagios@nagiosxi root]$ ls -al /var/www/.ssh
ls: cannot access /var/www/.ssh: No such file or directory
[nagios@nagiosxi root]$ cat /var/www/.ssh/id_dsa
cat: /var/www/.ssh/id_dsa: No such file or directory
[nagios@nagiosxi root]$ cat /var/www/.ssh/id_dsa/known_hosts
cat: /var/www/.ssh/id_dsa/known_hosts: No such file or directory
# Below is the result for check_by_ssh version check
[nagios@nagiosxi root]$ /usr/local/nagios/libexec/check_by_ssh -V
check_by_ssh v1.5 (nagios-plugins 1.5)
vi-admin@vma:~>
logout
It looks like these steps were missed as @Box293 mentioned -
Please run through this, and let us know the result.
mkdir /var/www/.ssh
coopstudent
# below command did produce outputJust completed steps as required by the vMA Settings Manager component
mkdir /var/www/.ssh
[root@nagiosxi ~]# ls -al /var/www/
total 8
drwxr-xr-x. 6 root root 53 Feb 9 16:11 .
drwxr-xr-x. 23 root root 4096 Feb 9 09:07 ..
drwxr-xr-x. 2 root root 6 Nov 19 16:43 cgi-bin
drwxr-xr-x. 3 root root 37 Feb 4 22:02 html
drwxr-xr-x. 2 root root 4096 Feb 4 21:54 mrtg
drwxr-xr-x+ 2 root root 37 Feb 9 16:11 .ssh
[root@nagiosxi ~]# ls -al /var/www/.ssh/
total 8
drwxr-xr-x. 6 root root 53 Feb 9 16:11 ..
-rw-r-x---+ 1 root root 668 Feb 9 16:11 id_dsa
-rw-r-xr--+ 1 root root 174 Feb 9 16:11 known_hosts
I still have the same issue
- Box293
- Too Basu
Now that you have made those changes, lets test as the apache user:coopstudent wrote:# below command did produce outputJust completed steps as required by the vMA Settings Manager component
mkdir /var/www/.ssh
total 8
total 8
/usr/local/nagios/libexec/check_by_ssh -E 1 -l vi-admin -H 10.XXX.XXX.XXX -C '~/box293_check_vmware.pl --server 10.ZZZ.ZZZ.ZZZ --version'As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
coopstudent
# below command did prompt for credentials
[nagios@nagiosxi root]$ su -s /bin/sh apache
Password: ^C
#below command did NOT prompt for credentials
# below command did NOT prompt for credencials and did produced output
Password: ^C
- Box293
- Too Basu
So we need to be able to test this as the apache user as this is the user account that the vMA settings manager runs as.coopstudent wrote:# below command did prompt for credentials
Password: ^C
If you are being prompted for a password for the apache user, then you will need to type it in so you can execute the next commands as the apache user.
On my XI box I do not get prompted.
[root@xitest ~]# su -s /bin/sh apache
sh-4.1$ As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
coopstudent
In my previous reply, I tried the command as nagios user. Now I tried as root
# below command did NOT prompt for credentials
[root@nagiosxi ~]# su -s /bin/sh apache
sh-4.2$
sh-4.2$
