Can't locate Mail/Sendmail.pm in @INC
rkymtnhigh
Post by rkymtnhigh »
I have loaded a plugin that will send an email when a condition is met (packet loss in this case).
When I try to run a test, I receive the following error:
Can't locate Mail/Sendmail.pm in @INC (@INC contains: /usr/local/nagios/perl/lib/Getopt/ /usr/local/nagios/perl/lib/ /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_ping_L2 line 14.
BEGIN failed--compilation aborted at ./check_ping_L2 line 14.
I've done a little googling but can't seem to find a solution. Any help is appreciated!
Thanks!
RMH
Re: Can't locate Mail/Sendmail.pm in @INC
Try running:
yum -y install perl-Mail-Sendmail
Did this fix the issue?
rkymtnhigh
Yes! That seems to have taken care of it. Thanks for pointing me in the right direction!
bwallace
Post by bwallace »
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
