-When nagios restarts it says that there are duplicate definitions. When I check this in the .cfg file it isn't true. There are no duplicate definitions
-For some reason when I add a host which I previously added and then deleted it still uses services from the previous configuration.
Example: I only want a ping service for a specific host, but in the past it used to have some VMware services so it puts them in the view. When I check the services in the configuration manager they aren't there. Manually configuring the ping service puts the VMware services in the view as well.
When I check the VMware services and try to delete them in the view it says they don't have an unique ID.
Please help
