This node handles syslogs and file input of apache log files.
Seeing a lot of these...
{:timestamp=>"2016-02-08T13:31:47.687000-0800", :message=>"retrying failed action with response code: 503", :level=>:warn}
{:timestamp=>"2016-02-08T13:31:47.687000-0800", :message=>"retrying failed action with response code: 503", :level=>:warn}Code: Select all
{:timestamp=>"2016-02-08T17:21:07.070000-0800", :message=>"retrying failed action with response code: 429", :level=>:warn}
{:timestamp=>"2016-02-08T17:21:07.071000-0800", :message=>"retrying failed action with response code: 429", :level=>:warn}
{:timestamp=>"2016-02-08T17:21:07.071000-0800", :message=>"retrying failed action with response code: 429", :level=>:warn}Code: Select all
{:timestamp=>"2016-02-08T23:55:26.035000-0800", :message=>"failed to open /nfs/shared/somelogs:
Permission denied - /nfs/shared/somelogs", :level=>:warn}
{:timestamp=>"2016-02-08T23:55:26.509000-0800", :message=>"syslog listener died", :protocol=>:tcp, :address=>"0.0.0.0:5544", :exception=>#<SocketError: probl
em when accepting>, :backtrace=>["org/jruby/ext/socket/RubyTCPServer.java:174:in `accept'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems
/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:155:in `tcp_listener'", "org/jruby/RubyKernel.java:1511:in `loop'", "/usr/local/nagioslogserver/lo
gstash/vendor/bundle/jruby/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:154:in `tcp_listener'", "/usr/local/nagioslogserver/logstash/ve
ndor/bundle/jruby/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:117:in `server'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jru
by/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:101:in `run'"], :level=>:warn}
{:timestamp=>"2016-02-08T23:55:26.791000-0800", :message=>"A plugin had an unrecoverable error. Will restart this plugin.\n Plugin: <LogStash::Inputs::File
path=>[\"<PATHS>"], type=>\"iplanet\", tags=>[\"ipla
net-DMZ\"], start_position=>\"end\", delimiter=>\"\\n\">\n Error: Bad file descriptor - Bad file descriptor", :level=>:error}
{:timestamp=>"2016-02-08T23:55:26.824000-0800", :message=>"UDP listener died", :exception=>#<SocketError: recvfrom: name or service not known>, :backtrace=>[
"/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-udp-0.1.4/lib/logstash/inputs/udp.rb:79:in `udp_listener'", "/usr/local/nagi
oslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-udp-0.1.4/lib/logstash/inputs/udp.rb:49:in `run'", "/usr/local/nagioslogserver/logstash/vend
or/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/pipeline.rb:176:in `inputworker'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.
9/gems/logstash-core-1.5.1-java/lib/logstash/pipeline.rb:170:in `start_input'"], :level=>:warn}
{:timestamp=>"2016-02-08T23:55:26.878000-0800", :message=>"Unknown error while looking up GeoIP data", :exception=>#<Errno::EBADF: Bad file descriptor - Bad
file descriptor>, :field=>nil, :event=>#<LogStash::Event:0x22437c03 @metadata={}, @accessors=#<LogStash::Util::Accessors:0x3ebf475c Now some of these access and error files don't have much entries in them and only has the header....
format=%Ses->client.ip% - %Req->vars.auth-user% [%SYSDATE%] "%Req->reqpb.clf-request%" %Req->srvhdrs.clf-status% %Req->srvhdrs.content-length%
snapshot of the permissions...
-rw-r--r-- 1 30002 300 143 Feb 1 23:55 access.201602022355
-rw-r--r-- 1 30002 300 143 Feb 2 23:55 access.201602032355
-rw-r--r-- 1 30002 300 143 Feb 3 23:55 access.201602042355
-rw-r--r-- 1 30002 300 143 Feb 4 23:55 access.201602052355
-rw-r--r-- 1 30002 300 143 Feb 5 23:55 access.201602062355
-rw-r--r-- 1 30002 300 143 Feb 6 23:55 access.201602072355
-rw-r--r-- 1 30002 300 143 Feb 7 23:55 access.201602082355
