Just wondering if its possible to replace plugin path in nrpe.cfg with $ARG1$? Goal is to use one single line in npre.cfg and Pass plugin path including arguments from nagios server for complete control and flexibility ?.
Eg:-
command[Check_service]=/Path/To/nagios/plugins/check_service.sh $ARG1$ can it be replaced as
command[Check_service]=$ARG1$
It tried but failed.?
Any help will be appreciated,
Replace Plugin path with $ARGU$ in nrpe.cfg
alokispandey
Re: Replace Plugin path with $ARGU$ in nrpe.cfg
I can't say I've ever tried, but the security issues this could open up are pretty endless.
Example of one of the terrible things that could go wrong... Don't run this!:
Is that something you want open in your environment?
./check_nrpe -H x.x.x.x -c /usr/bin/rm -rf /Former Nagios Employee.
me.
me.
Yes, though it will not work with all linux commands, and the output is limited. Here's a sample -
Modify /usr/local/nagios/etc/nrpe.cfg, and change two fields to reflect below -
then, add this as the command -
Restart xinetd (service xinetd restart), and it should be working.
[root@suse11 libexec]# ./check_nrpe -H 192.168.3.42 -c rootterm -a 'uptime'
10:36:52 up 16 days, 17:44, 1 user, load average: 0.00, 0.00, 0.00
[root@suse11 libexec]# ./check_nrpe -H 192.168.3.42 -c rootterm -a 'whoami'
nagios
10:38:23 up 16 days, 17:45, 1 user, load average: 0.00, 0.00, 0.00
[root@suse11 libexec]# ./check_nrpe -H 192.168.3.42 -c rootterm -a 'users'
root
[root@suse11 libexec]# ./check_nrpe -H 192.168.3.42 -c rootterm -a 'ps -ef'
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 Jan25 ? 00:00:01 /sbin/init
root 2 0 0 Jan25 ? 00:00:00 [kthreadd]
root 3 2 0 Jan25 ? 00:00:00 [migration/0]
root 4 2 0 Jan25 ? 00:01:11 [ksoftirqd/0]
root 5 2 0 Jan25 ? 00:00:00 [stopper/0]
root 6 2 0 Jan25 ? 00:05:56 [watchdog/0]
root 7 2 0 Jan25 ? 00:10:39 [events/0]
root 8 2 0 Jan25 ? 00:00:00 [events/0]
root 9 2 0 Jan25 ? 00:00:00 [events_long/0]
root 10 2 0 Jan25 ? 00:00:00 [events_power_ef]
root 11 2 0 Jan25 ? 00:00:00 [cgroup]
root 12 2 0 Jan25 ? 00:00:00 [khelper]
root 13 2 0 Jan25 ? 00:00:00 [netns]
root 14 2 0 Jan25 ? 00:00:00 [async/mgr]
root 15 2 0 Jan25 ? 00:00:00 [pm]
root 16 2 0 Jan25 ? 00:00:05 [sync_supers]
root 17
[root@suse11 libexec]# ./check_nrpe -H 192.168.3.42 -c rootterm -a 'cat /home/nagios/cookie.txt'
# Netscape HTTP Cookie File
# http://curl.haxx.se/rfc/cookie_spec.html
# This file was generated by libcurl! Edit at your own risk.
localhost FALSE / FALSE 1455207162 nagiosxi m45pjocc5r3ibao92kr742bs75
dont_blame_nrpe=1
allow_bash_command_substitution=1
command[rootterm]=$ARG1$
alokispandey
Hsmit,
I understand the concerns here..but that is something that can be restricted by adding prefix sudo ( and restricting destructive command for user in sudoers).
Per "rkennedy" it will not support all linux command.. think of advantages, if it starts supporting all command and regex, how easy it will be to manage the nagios client and client changes will become a one time implementation only.
Thank you rkennedy for your steps,I am going to test it in my test env.
Let us know how the testing goes in your environment.
