Oracle Plugin error - Cant locate DBD/Oracle.pm in @INC
aap
Post by aap »
I am trying to install the Oracle plugins without much success. I have followed your document and also other forum posts on how to resolve this issue. The problem seems to be the installation of DBD::Oracle.
I have attached the output of the command:
cpan -i DBD::Oracle
Thanks for your assistance
Re: Oracle Plugin error - Cant locate DBD/Oracle.pm in @INC
It looks like the CPAN module is having issues with the Oracle 12.1 client, can you remove it and install the Oracle 11.2 simple client and try installing it again?
aap
Post by aap »
Looks good now. Thanks for your help.
