Installing NRPE on FreePBX Distro
Tim7473
Post by Tim7473 »
I'm just getting started with Nagios XI and I'm trying to install NRPE to monitor a FreePBX server. I'm getting an error on install that the OS version can't be determined. The FreePBX distro is based on CentOS, but it is reported as SHMZ release 6.6 (Final) instead of CentOS when I do cat /etc/redhat-release
Is there a way to get NRPE to successfully install?
Re: Installing NRPE on FreePBX Distro
You should be able to compile it from source, see this link -
IIRC SHMZ is just a fork based for FreePBX.
Tim7473
Post by Tim7473 »
I'm hitting an issue with SSL when I try to compile. Running ./configure gives me the error "checking for SSL headers... configure: error: Cannot find ssl headers"
When I try #which openssl I see it's installed at /usr/bin/openssl so I tried ./configure --with-ssl=/usr/bin/openssl and I'm still getting the error.
I haven't found many answers searching around. Any thoughts on getting past this?
Do you have the package openssl-dev (might be openssl-devel)?
Tim7473
Post by Tim7473 »
Installing OpenSSL-devel allowed me to compile and install, but now I'm getting the error "CHECK_NRPE: Error - Could not complete SSL handshake." when I try ./check_nrpe -H localhost. I'm also getting an error "connect to address <NAGIOS SERVER IP> port 5666: No route to host" when I try ./check_nrpe -H <NAGIOS SERVER IP>. I can ping the IP from this box though, so not sure if that's related. I also have NRPE running on another Ubuntu box, so I don't think there's an issue on the Nagios server.
I've gone through all the troubleshooting steps I could find for this error, including those in https://assets.nagios.com/downloads/nag ... utions.pdf
So far I've tried:
Making sure our Nagios server IP is in /usr/local/nagios/etc/nrpe.cfg
(Line from config: allowed_hosts=127.0.0.1,<NAGIOS SERVER IP>)
Making sure our Nagios server IP is in /etc/xinetd.d/nrpe and adding the per_source and instances lines
Lines from config file:
only_from = 127.0.0.1 <NAGIOS SERVER IP>
per_source = UNLIMITED
instances = UNLIMITED
Tried recompiling with --enable-ssl
Allowing port 5666 in IP tables just in case it was being blocked:
iptables -I INPUT -p tcp -m tcp --dport 5666 -j ACCEPT
No other firewalls are running one the box. I checked for CSF and APF.
Made sure the service was in /etc/services:
nrpe 5666/tcp
What happens if you run ./check_nrpe -H localhost -n? The -n will run it without SSL.
Please post the output.
Tim7473
Post by Tim7473 »
# ./check_nrpe -H localhost -n
CHECK_NRPE: Error receiving data from daemon.
Trying to check and make sure it's running:
netstat -at | grep nrpe
tcp 0 0 *:nrpe *:* LISTEN
I'm not sure if the netstat output looks correct?
From the Nagios machine, what is the result of a nmap freepbxserverip?
Also from the Nagios machine, what is the result of ./check_nrpe -H freepbxserverip -n?
Tim7473
Post by Tim7473 »
Host is up (0.061s latency).
Not shown: 987 closed ports
PORT STATE SERVICE
22/tcp open ssh
53/tcp open domain
80/tcp open http
81/tcp open hosts2-ns
83/tcp open mit-ml-dev
84/tcp open ctf
85/tcp open mit-ml-dev
443/tcp open https
5222/tcp open xmpp-client
5269/tcp open xmpp-server
5280/tcp open xmpp-bosh
5666/tcp open nrpe
8088/tcp open radan-http
and
./check_nrpe -H <FREEPBXIP> -n
Are you running NRPE under xinetd or standalone?
ps -ef|grep nrpe
Also - after making changes to the config file, did you restart your service?
