Here's what a manual check looks like:
# /usr/local/nagios/libexec/check_http -H XXXX -S --ssl=1 -vvv
CRITICAL - Cannot make SSL connection.
140076210550720:error:14094410:SSL routines:SSL3_READ_BYTES:sslv3 alert handshake failure:s3_pkt.c
Here's an nmap scan of my webserver showing the ciphers supported:
# nmap --script ssl-enum-ciphers -p 443 XXXX
Starting Nmap 6.47 ( http://nmap.org ) at 2016-02-13 19:01 CST
Nmap scan report for XXXX (140.32.112.244)
Host is up (0.00095s latency).
PORT STATE SERVICE
443/tcp open https
| ssl-enum-ciphers:
| SSLv3: No supported ciphers found
| TLSv1.0:
| ciphers:
| TLS_DHE_RSA_WITH_AES_128_CBC_SHA - strong
| TLS_DHE_RSA_WITH_AES_256_CBC_SHA - strong
| TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA - strong
| TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA - strong
| TLS_DHE_RSA_WITH_SEED_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_RC4_128_SHA - strong
| compressors:
| NULL
| TLSv1.1:
| ciphers:
| compressors:
| NULL
| TLSv1.2:
| ciphers:
| TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 - strong
| TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 - strong
| TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 - strong
| TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 - strong
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 - strong
| TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 - strong
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 - strong
| TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 - strong
| compressors:
| NULL
|_ least strength: strong
Nmap done: 1 IP address (1 host up) scanned in 0.67 seconds
According to check_http help, the relevant parameters it expects are such:
-S, --ssl=VERSION
Connect via SSL. Port defaults to 443. VERSION is optional, and prevents
auto-negotiation (1 = TLSv1, 2 = SSLv2, 3 = SSLv3).
This is on a fresh install of Nagios XI Version : 5.2.3, running on CentOS 7.
Any help would be much appreciated.
Thank you.
