ERROR: Invalid return from command: check_drivesize
Hi Team,
On few of the Windows boxes I am getting below error for W: Drive monitoring. However C: Drive monitoring working fine. W: drive is present on these servers. Please Help.
COMMAND: /usr/local/nagios/libexec/check_nt -H irv-xxx-03.abc.net -s "" -p 12489 -v USEDDISKSPACE -l W -w 85 -c 90
OUTPUT: NSClient - ERROR: Invalid return from command: check_drivesize
COMMAND: /usr/local/nagios/libexec/check_nt -H irv-xxx-03.abc.net -s "" -p 12489 -v USEDDISKSPACE -l C -w 85 -c 90
OUTPUT: C:\ - total: 114.90 Gb - used: 63.80 Gb (56%) - free 51.10 Gb (44%) | 'C:\ Used Space'=63.80Gb;97.66;103.41;0.00;114.90
Re: ERROR: Invalid return from command: check_drivesize
What is the NSClient++ version that you are currently using?
How large is drive W:? Is this a network drive?
/usr/local/nagios/libexec/check_nt -H <client ip> -s "password" -p 12489 -v CLIENTVERSIONBe sure to check out our Knowledgebase for helpful articles and solutions!
Nagios agent version is 0.4.3.143. W: drive is not network drive and have same size as of C: drive (120GB)
Are the permissions on C and W the same?
Former Nagios Employee.
me.
me.
This seems like a bug in NSClient++. Check out this issue I created. It was solved in 0.5.0.17.
https://github.com/mickem/nscp/issues/202
Could you try the latest NSClient version, which is 0.5.0.22 and test if the issue is solved?
https://github.com/mickem/nscp/releases/tag/0.5.0.22
Grtz
Grtz
Nagios XI 5.8.1
https://outsideit.net
jyoti22, have you tried upgrading NSClient++ as suggested by WillemDH? Did this resolve the issue?
Thanks. I'll upgrade the version and keep you posted on update.
Sounds good, let us know the result.
Upgraded agent to version 0.5.0.22. However still same error on W: drive monitoring.
Can you post the full input / output once again on this new version? I'd like to see if anything changed.
Also, what version of check_nt are you running?
/usr/local/nagios/libexec/check_nt -V
