I can create testcases and config files, but once they are written the permissions are apache:nagios 744. So once I create as nagios, the nagios user has read only.
This makes it impossible to go back and edit test cases or if I want to test changing the user-agent.
This all worked fine before the upgrade. Right now I am working around it with the Config Wizard via the GUI. Not being able to edit files after the fact is making my job harder. It also makes it much much hard to test out test cases before deploying them to production as anyone that has used web-inject knows sometimes it can take a few test runs to get everything correct. The new permission makes this impossible as after I create it (Nagios user) I cannot edit it.
Created with Gui. As you can see, if I need to update the user-agent, the nagios user would not have permissions to edit the file the way it did before.
-rw-r--r-- 1 apache nagios 218 Feb 15 11:55 node.domain.com__Web_Transaction_config.xml
-rw-r--r-- 1 apache nagios 331 Feb 15 11:55 node.domain.com__Web_Transaction_testdata.xml
