notification based on status information/data
marcha83
Post by marcha83 »
Is there any possibility under nagios XI settings to gets notification based on status information/data (attached picture), similar to SNMP trap monitoring?
For example, I'm using 'check_multi' plugin who check about 10 tcp listen ports on one server, so my problem is that when any of this ports going down I get first notification and the service state is critical, wich is ok, but in next check it can be situation that another parallel port is also down and in this situation I don't get notification because of the first one. So for me it would be great when I could get notification based on every status information changes, something like stalking options for logging.
Re: notification based on status information/data
This is a duplicate thread, please continue this discussion in your original one.
https://support.nagios.com/forum/viewto ... =7&t=37091
