Toshiba printer e182 monitoring code
jaseem.abdu
Please letme know the monitoring config statements for toshiba estudio 182... i mean the check_command for printer service monitoring....i am using the default code supplied for hp...hpjd...but it shows critical error in nagios...which i suppose is due to command error....... am new to nagios learning
Re: Toshiba printer e182 monitoring code
Have you looked at our exchange (https://exchange.nagios.org) to see if any of the plugins will work for you?
jaseem.abdu
Yes doenot exist for toshiba. can you please help me how to use a downloaded plugin file
jaseem.abdu
I have downloaded check_printer...i dont know how to use that plugin script....how to install iit
You'll need to download it to /usr/local/nagios/libexec/ (our standard plugins directory), then chmod +x file.
You'll then need to create a command definition, and assign it to a service. Here's a couple links that will further explain it -
Command definitions - https://assets.nagios.com/downloads/nag ... ml#command
Service definition - https://assets.nagios.com/downloads/nag ... ml#service
