I have downloaded the VM several times and have tried to get it up and running several times as well and at about 65% installed it just dies and gives the following log file.
I have a webinar tomorrow at 11am CST with sales to ask questions and learn about the products and I'd like to have my machine up and running as well.
Nagios XI and VMPlayer 6.0.7 32bit
JMorris207
Re: Nagios XI and VMPlayer 6.0.7 32bit
Can you show us a screenshot where you are seeing that log file? I'm confused on how you're trying to install at this point.
You should be able to download https://assets.nagios.com/downloads/nag ... 2.3-64.ova directly, and open that with VMPlayer.
If this doesn't work, you can always spin up a Centos 5-7 machine and run through our manual install here -
https://assets.nagios.com/downloads/nag ... ctions.pdf
JMorris207
Attached is a combined image of the steps I took to install/setup the OVF file
JMorris207
It is not.
Have you tried the 64 bit version of the ova?
Former Nagios Employee.
me.
me.
JMorris207
When I tried it, it said processor was not supported. I asumme because I'm running the 32 bit version of windows, and 32 bit version of vmware as its the only one that will install.
Do you have access to vmware workstation? I got it to work on 32 bit workstation, but I have not attempted player yet. I'm going to look for a player installation and see if I can replicate.
me.
me.
JMorris207
VM Workstation won't install on a 32 bit distribution of windows so I can't use that.
I have VM Workstation 9.0 installed on my 32 bit Windows 7 machine.
me.
me.
