Check Peer BGP State Fortigate
Icarus
Post by Icarus »
After searching unsuccessfully SNMP OID showing the status of a BGP peer on a Fortigate.
I am now looking a check to monitor the status of BGP peer a Fortigate.
Best regards
Re: Check Peer BGP State Fortigate
Have you looked at our Exchange (https://exchange.nagios.org) to see if any of the plugins will work for you?
https://exchange.nagios.org/index.php?o ... chword=bgp
