check_nt (server port must be an integer) error
tejanagios
HI,
check_nt in nagios xi, when trying to configure it via ccm, throws an error, saying server port must be an integer when trying to pull info from nsclient++, the client is running fine and gives output
from the command line.
Also, what does check_Xi_service use as its transport mechanism in the background?
Re: check_nt (server port must be an integer) error
This usually happens when the port is defined twice - in the command, and in the service. Can you show us the command, and service confgs? Also, show us the actual command that you run from the command line along with the output of it.check_nt in nagios xi, when trying to configure it via ccm, throws an error, saying server port must be an integer...
Are you talking about the "check_xi_service_nsclient" command? It is simply calling the "check_nt" command:Also, what does check_Xi_service use as its transport mechanism in the background?
command_name check_xi_service_nsclient
command_line $USER1$/check_nt -H $HOSTADDRESS$ -s "$ARG1$" -p 12489 -v $ARG2$ $ARG3$ $ARG4$
}Be sure to check out our Knowledgebase for helpful articles and solutions!
Can you post a screenshot of the check_nt issue so we can see what you're referring to?
tejanagios
## I have used the wizard to create a service for the host ending with .18 ip address, but now iam trying to check the service for host with ip ending .13 from nagios xi:
The reason basically is because, after adding hosts through the config wizard, the service names have the names of the hosts in the services menu filtering under CCM, instead of the service name itself.
so, instead of using the wizard, if i add services that i like and make them into a service group and apply the service group to a host group, ( or can i pick all the services that i like and make a template?) please throw me a good documentation on how to create and or use service templates please) I think it is more linear approach, please correct me if i am wrong in thinking how things work in
nagios xi?
here is the output yo've requested.
[root@nagios-server services]# vi 172.24.48.18.cfg
# Service configuration file
# Created by: Nagios Core Config Manager 2.5.2
# Date: 2016-02-16 16:55:30
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
host_name 172.24.48.18
service_description Drive C: Disk Usage
use xiwizard_windowsdesktop_nsclient_service
check_command check_xi_service_nsclient!2willpass!USEDDISKSPACE!-l C -w 80 -c 95
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
notifications_enabled 0
contacts nagiosadmin
_xiwizard windowsdesktop
register 1
service_description Memory Usage
check_command check_xi_service_nsclient!2willpass!MEMUSE!-w 80 -c 90
check_interval 5
retry_interval 1
register 1
########################################### NAGIOS XI SERVICES COMMAND LINE OUTPUT HERE: screen shot attached to a file pls check.
COMMAND: /usr/local/nagios/libexec/check_nt -H 172.24.48.13 -p $USER7$ -s $USER8$ -v MEMUSE
OUTPUT: Server port must be an integer
nagios xi?
check_interval 5
retry_interval 1
register 1
check_interval 5
retry_interval 1
register 1
I think you're confusing $ARG$ values, with $USER$ macros.
Can you please post the contents of this file?
cat /usr/local/nagios/etc/resource.cfg
$USER7$ and $USER8$ are not the same as $ARG7$ and $ARG8$... The $USER7$ and $USER8$ macros are grabbed from the "/usr/local/nagios/etc/resource.cfg" file. Clear the $USER7$ and $USER8$ fields, enter the warning & critical thresholds in the $ARG2$ fields, save and try your check again.
Here's an example of a similar service on my test box:
You can set up one service the way you want it, then add it to a host group by clicking on the "Manage Hostgroups" under the "Service Management" ("Common Settings" tab).
You can also review our documentation on object inheritance here:
https://assets.nagios.com/downloads/nag ... tance.html
tejanagios
== resources.cfg file contents
[root@nagios-server etc]# cat resource.cfg
# Path to the plugins
$USER1$=/usr/local/nagios/libexec
# Path to event handlers
#$USER2$=/usr/local/nagios/libexec/eventhandlers
# Port for NSClient++
$USER7$=12489
# Password for NSClient++
$USER8$=secret
##check_nt command definition from commands.cfg####
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p $USER7$ -s $USER8$ -v $ARG1$ $ARG2$
service definition for that object
host_name QA-WTS1
service_description check memory
check_command check_nt!MEMUSE!-w 80 -c 90!!!!!!
check_period 24x7
register 1
the check_command check_nt hasn't got any password or port number passed on in the command output on the gui at nagios xi.
$USER7$=12489
$USER8$=secret
host_name QA-WTS1
check_period 24x7
register 1
Replace:
with:
in the resource.cfg file, and you should be good to go. Testing from the CCM may still fail with "Server port must be an integer" but the check should work fine.
Go to Home->Service Detail->check memory, and force an immediate check. Let us know if this worked.
$USER8$=secretCode: Select all
$USER8$=<your actual password>Go to Home->Service Detail->check memory, and force an immediate check. Let us know if this worked.
tejanagios
HI lmitchev,
thank you, that works now. what if I need to apply this service to a host group, how do I go changing the passwords for all of them ?
how does check_xi_service pick passwords for different hosts without any entries in the resources.cfg file ?
You can use the "check_xi_service_nsclient" command instead in your service, for example:thank you, that works now. what if I need to apply this service to a host group, how do I go changing the passwords for all of them ?
service definition
host_name myhost
hostgroup_name windows-servers
check_command check_xi_service_nsclient!$_HOSTPASS$!MEMUSE!-w 80 -c 90!!!!!
check_interval 5
retry_interval 1
first_notification_delay 0
_xiwizard windowsserver
register 1
}Code: Select all
}CCM->Hosts-><your host>->Misc Settings->Manage Variable Definitions, then set:
Variable name = _PASS
Variable value = <the NSClient++ password on this Windows server>
Close, save, and apply configuration.
When the macro is used this way in the service definition:
you will have the correct password for each host passed to $ARG1$.$_HOSTPASS$
Hope this helps.
