Service timeout
ohlssrog
Service timeout
Post by ohlssrog »
Hi.
We did an XI upgrade this monday from 2012R1.7 to 5.2.3 in 6 step upgrade. The problem we have after the upgrade is with the webinject checker.
I i run the command in ssh line
check_xi_service_webinject_sh!SLSV65_Test_BOI.xml
Output
could not find ParserDetails.ini in /usr/lib64/perl5/XML/SAX
Use of uninitialized value $scheme in pattern match (m//) at /usr/lib64/perl5/HTTP/Cookies.pm line 45.
WebInject CRITICAL - Unable to open BOI webpage |time=115.794;45;;0
I cannot find the file ParserDetails.ini in the path ../SAX/
I attach the xml, if you want i can pm the "data.xml" file to you?
Re: Service timeout
It looks like you may be missing a package. Can you run this command and let us know the result?
yum install perl-XML-SAX -y
ohlssrog
Re: Service timeout
Post by ohlssrog »
I get
Package perl-XML-SAX-0.96-7.el6.noarch already installed and latest version
Nothing to do
Re: Service timeout
What is the output of a whereis perl?
ohlssrog
Re: Service timeout
Post by ohlssrog »
perl: /usr/bin/perl /usr/share/man/man1/perl.1.gz
Re: Service timeout
Can you also post the file SLSV65_Test_BOI_testdata.xml for us to look at?
