LDAP Integration is failing
jeffersont
Post by jeffersont »
I'm doing a POC for Nagios XI and encounter a problem with LDAP integration.
The error I got is "Unable to authenticate: Could not connect to the LDAP server selected."
I can login to the Nagios server using my IPA account and can also do a ldapsearch from the Nagios Server.
I'm pretty sure I got the correct setting for LDAP.
When I check the LDAP server logs, this is what I can see...
[18/Feb/2016:01:15:41 -0800] ipalockout_postop - [file ipa_lockout.c, line 503]: Failed to retrieve entry "CN=XXXXXX,dc=XXXXXXXX,dc=XXXXXXX": 32
I find it weird that under the CN=, it shows the user account that I use to authenticate which is not a Common Name...Not sure if CN there do stands for Common Name.
Any Ideas?
hsmith
Agent Smith
Re: LDAP Integration is failing
Post by hsmith »
What version of XI are you using?
Former Nagios Employee.
me.
jeffersont
I'm using this version.
Installed Version: 5.2.4
Can you show us a screenshot of your configuration on the XI interface?
