We are migrating the nagios architecture to the last version.
After apply configuration, the "nagios process run" don't start until 30 minutes after.
My nagios architecture: NagiosXI 5.2.5 (Today I upgrade to the last version)
Offload Mysql to a ha arch.
OS: Red Hat Enterprise Linux Server release 6.7 (Santiago).
Virtal Machin with 16 cores and 8GB RAM
Mod_gearman with 3 worker (VM: RHEL 6.7,8 Cores,8GB ram [+ active worker then nagiosxi app server])
RamDisk, mrtg with rrdcache, pasive checks have not even.
The gneric check time interval is in 10 minutes.
1200 host, 7200 services (this will double when finished migration)
Mysql
contactnortifications
mysql> select count(*) from nagios_contactnotifications;
| count(*) |
| 897 |
1 row in set (0.00 sec)
| count(*) |
| 898 |
# Controls the use of TCP syncookies
net.ipv4.tcp_syncookies = 1
# Controls the default maxmimum size of a mesage queue
kernel.msgmnb = 131072000
# Controls the maximum size of a message, in bytes
kernel.msgmax = 131072000
# Controls the maximum shared segment size, in bytes
kernel.shmmax = 4294967295
# Controls the maximum number of shared memory segments, in pages
kernel.shmall = 268435456
## The maximum number of messages allowed in any one message queue
kernel.msgmni = 2560000
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
# Gearman module
broker_module=/usr/lib64/mod_gearman/mod_gearman.o config=/etc/mod_gearman/mod_gearman_neb.conf eventhandler=no
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/var/nagiosramdisk/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$\tLONGSERVICEOUTPUT::$LONGSERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
host_perfdata_file=/var/nagiosramdisk/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$\tLONGHOSTOUTPUT::$LONGHOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=1
auto_rescheduling_interval=30
auto_rescheduling_window=45
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/var/nagiosramdisk/spool/checkresults
check_service_freshness=1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
high_host_flap_threshold=20.0
host_check_timeout=30
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_external_commands=0
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=0
log_rotation_method=d
log_service_retries=1
low_host_flap_threshold=5.0
max_check_result_reaper_time=30
max_concurrent_checks=0
max_debug_file_size=1000000
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/var/nagiosramdisk/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
perfdata_timeout=5
precached_object_file=/usr/local/nagios/var/objects.precache
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=60
service_interleave_factor=s
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/var/nagiosramdisk/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/var/nagiosramdisk/tmp
use_regexp_matching=0
use_retained_program_state=1
use_syslog=1
use_true_regexp_matching=0
Process monitor after 20 minutes
Process monitor in green
Regards
