Config Error
operations_asavie
Config Error
Can you help me please, am running into a Config Error when applying configuration changes.
Even when I revert back to a previous snapshot that has "Config Ok" in the Snapshot Result and the following output when I view the config.I still get the error below. Can you please help with this?
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 409 services.
Checked 13 hosts.
Checked 4 host groups.
Checked 1 service groups.
Checked 2 contacts.
Checked 2 contact groups.
Checked 126 commands.
Checked 8 time periods.
Checked 0 host escalations.
Checked 13 hosts
Checked 0 host dependencies
Checked 8 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Error: Invalid max_check_attempts value for host 'XXXX'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/XXXX', starting on line 16)
Nagios Core 4.1.1
License: GPL
Checking objects...
Checked 13 hosts.
Checked 2 contacts.
Checked 13 hosts
Total Warnings: 0
Total Errors: 0
operations_asavie
Re: Config Error
See the downloaded snapshot attached.
Re: Config Error
Re: Config Error
rkennedy is correct, but you could quickly check to confirm the settings are at least correct for "'max_check_attempts' on the host in question.
Go to :
Core Config Manager > Hosts > and Select the host in question so the 'Host management' window appears. Click the 'Check Settings' tab and make sure Check / Retry intervals have values as well as 'Max check attempts.' Anything with with a red asterisk next to it cannot be left blank either. Also fill out the notification period under the 'Alert Settings' tab.
Save changes and apply config - this should do away with those errors, but new errors may be revealed instead. If issue persists, please provide more detail about the the host you're attempting to monitor (is it Linux or Windows machine, router or switch, is an agent such as NRPE installed on it, etc) as rkennedy mentioned.
Go to :
operations_asavie
Re: Config Error
Host is C8T14Y1.mgmt, have configured the check settings (see image attached) similar to all other hosts that are not causing any errors.
The host is a Dell server.
Anything else you need, please let me know as I need to get this resolved ASAP.
Re: Config Error
Did you try applying configuration after modifying this host under the CCM, and saving the changes? Do you see any config errors when you run the Write Config tool?
CCM->Tools->Write Config Files->Write->Verify
Can you show us the configs of the "C8T14Y1.mgmt" host, and the "linux-server" template?
operations_asavie
Re: Config Error
When using the Write Config files tool CCM I am seeing all config files verified and then successfully written.
However, when I've gone to use the standard "Apply Configuration" the error below still persists. I've even gone so far as deleting all services pertaining to that particular host and then deleting the host but even then when I try to apply the configuration......I still get the same error, even though the host C8T14Y1.mgmt.cfg has been deleted.
Error: Invalid max_check_attempts value for host 'C8T14Y1.mgmt'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/C8T14Y1.mgmt.cfg', starting on line 16)
Re: Config Error
How are you deleting the services? You're making sure to do it in CCM instead of from the command line, correct?
Former Nagios Employee.
me.
me.
operations_asavie
Re: Config Error
Yes, that's correct. I CCM, selecting "Services" in Monitoring then deleting all services. Then selecting "Hosts" in Monitoring and deleting all the hosts. When I do this, the Apply Configuration fails due the error I've outlined.
operations_asavie
Re: Config Error
I need a resolution to this ASAP. It's been two days since I've raised this issue with you.
Right now, I have only one service in operation on one host but despite this and the C8T14Y1.mgmt host being deleted. It's still presents an Error when Applying a Configuration.
Can you please get back to me on this right away?
