Paging to mobile phones
gregwhite
Post by gregwhite »
Can you recommend any paging software that will work well with nagiosXI? The ideal would be software that can work with a rotating support schedule to minimize having to update who is currently on-call.
Greg
krobertson71
Re: Paging to mobile phones
Post by krobertson71 »
I would definitely look at pagerduty.com.
It integrates with Nagios and lets your teams create their own schedules, rotating and otherwise. You can , I believe, set up the on-call calendar a year in advance.
Worth a look.
Not a free service.
Thanks, krobertson71!
@gregwhite
Here's the "Nagios XI Integration Guide" (from the pegerduty.com website):
https://www.pagerduty.com/docs/guides/n ... ion-guide/
Hope this helps.
gregwhite
Post by gregwhite »
Thanks!! Appreciate your help.
Will definitely check it out.
Greg
You are welcome! I am locking this thread now. If you have any more questions/issues, please start a new one.
