i've a problem with import user from a ldap server.
when i try to login with my admin credentials i recive this error:
Unable to authenticate: Could not connect to the LDAP server selected.
ill just configured the ldap auth from the web page may i have to configured something else?
pls i need some help i dind't found nothing about this problem.
Ty
Bye
LDAP / Active Directory Integration Configuration
Re: LDAP / Active Directory Integration Configuration
Can you show us a screenshot of the settings you're attempting to use?
i uploaded the info.
i'm still can't import users.
i've to configure too the openldap config?
can some1 helps me?
Are you running FreeIPA or what LDAP server are you running?
If it's FreeIPA, make sure to upgrade to XI 5.2.5, it contains some fixes for FreeIPA.
Have you tried specifying your full DN as the username when importing?
uid=admin,cn=users,cn=accounts,dc=example,dc=comRe: LDAP / Active Directory Integration Configuration
bur i had to configure some other file like httpd.conf?
Nothing should need to change in your HTTPD configs for XI LDAP authentication, it's form based and is handle by the application instead of HTTPD.
Please answer the questions from my previous post.
Thank you
Thank you
ssax wrote:Are you running FreeIPA or what LDAP server are you running?
It's a FreeIPA and it is up to date.
Thanks for confirming.What was the outcome of this previous question?
uid=admin,cn=users,cn=accounts,dc=example,dc=comHave you tried specifying your full DN as the username when importing?
Can you navigate to Admin -> Manage Components -> Look for 'LDAP / Active Directory Integration' - what version of the component are you currently utilizing?
