Greetings and thank you.
SOLVED. the map is blank. Error
zurrachillo
Hello I installed Nagios version 4.1.1 on a CentOS core 7 I copied my folder object I had in my previous Nagios and everything works fine unless the map, an image attachment appears empty if anyone knows what the problem is.
Re: the map is blank. Error
Did you follow any set of instructions when installing core? I wrote up this document, https://assets.nagios.com/downloads/nag ... entos7.pdf. My network map is showing up fine.
What is the output of getenforce?
zurrachillo
I've looked at your document and have everything set equal to the document.rkennedy wrote:Did you follow any set of instructions when installing core? I wrote up this document, https://assets.nagios.com/downloads/nag ... entos7.pdf. My network map is showing up fine.
if I write getenforce shows me Disabled.
In the empty map if I press "View Status Detail For This Host" show me "The requested URL was not found /nagios/status.cgi on this server."
thanks
zurrachillo
SOLVED. The problem is the link because in the new versions Map and Legacy appears, if I click on map appears to me empty but if I press legacy if it works, so I modified the "side.php" to make good link.
Thank you very much for the help.
a greeting
a greeting
Re: SOLVED. the map is blank. Error
It sounds like you solved this on your own!
We're here to help. Feel free to create a new thread if you need assistance in the future.
