Fresh 5.2.3 install, no autopostgresqlbackup script?
vAJ
Post by vAJ »
Noticed some cron errors for autopostgresqlbackup:
/bin/sh: /root/scripts/autopostgresqlbackup: No such file or directory
Sure enough. No file present. MySQL script is there and runs fine. Checked the install log, no reference to it. cron references that are called by install script create the job, but the dbbackups script fails to copy the file (it's not even in /tmp/nagiosxi/nagiosxi)
[root@brnxip01 nagiosxi]# cat nagiosxi.cron.d
# /etc/cron.d/nagiosxi: crontab fragment for nagiosxi
# Backup MySQL & PostgreSQL Databases
0   7 * * * root   /root/scripts/automysqlbackup
0   8 * * * root   /root/scripts/autopostgresqlbackup
9-dbbackups:
[root@brnxip01 nagiosxi]# cat 9-dbbackups
#!/bin/bash -e
. ./xi-sys.cfg
# Was previous step completed?
if [ ! -f installed.selinux ]; then
        echo "SELinux was not configured - run previous script" >&2
        exit 1
fi
# Was this step already completed?
if [ -f installed.dbbackups ]; then
        echo "Database backups already configured - skipping."
        exit 0
fi
mkdir -p /store/backups/mysql /store/backups/nagiosxi /root/scripts
chown "$nagiosuser:$nagiosgroup" -R /store/backups/nagiosxi
cp nagiosxi/automysqlbackup /root/scripts
echo "Database backups configured OK"
touch installed.dbbackups
Do I need to grab this script or drop the cron job?
Andrew J. - Do you even grok?
Re: Fresh 5.2.3 install, no autopostgresqlbackup script?
You can just drop the cron job. Postgres is no longer used in the new installs of XI. The data is stored in the "nagiosxi" database in mysql instead. You can double check if this is the case on your system by running:
echo '\d' | psql nagiosxi nagiosxi
and
echo 'show tables;' | mysql -t -u root -pnagiosxi nagiosxi
vAJ
Post by vAJ »
Sweet. When did I miss that change? I'll have to review changelog.
On a side note, the install scripts need to be sanitized to remove the addition of that cron job.
You are absolutely right. I will discuss this with our developers. In my opinion these two cron jobs:
don't need to be set up by default. These backups "saved the day" in a few cases, where we needed to restore the databases for customers, but in the majority of the cases they just take lots of disk space. :)
BTW, both - mysqld & postgres db (on older systems) are backed up anyway when you run the "/usr/local/nagiosxi/scripts/backup_xi.sh" script.
vAJ
Post by vAJ »
Exactly. I think we can lock this one up.
