Export table?
BanditBBS
Export table?
Post by BanditBBS »
Am I blind or is there now way to export a table to csv or some other format?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
jolson
Attack Rabbit
Re: Export table?
Post by jolson »
You are correct - there is currently no way to export information to a table/csv format. The best you can do at the moment is to use the elasticsearch API to query and get raw data back.
This is a highly requested feature, and it will be added in a future release when our developers come up with a solution. The next release is likely to contain user granularity, which means this issue is second in-line in terms of priority.
Twits Blog
BanditBBS
Re: Export table?
Post by BanditBBS »
"Your unique API key used for external API access. You can read more about what you can do with the API in the API documents in the help section."
I see no API section in the help section.
jolson
Attack Rabbit
Re: Export table?
Post by jolson »
You can query the API directly via the command line if you'd like - that way you don't need to involve the API key.
Example query:
    curl -XPOST "http://localhost:9200/_search?pretty" -d'
        "fields": ["user", "message", "type"],
        "query": {
            "filtered": {
               "filter": {
                  "range": {
                      "@timestamp": {
                       "from": "now-5m",
                                    "to": "now"
                    "query": {
                       "query_string": {
                        "query": "syslog"
You can change the 'from' field and the 'query' field as necessary - for instance:
        "query": {
            "filtered": {
               "filter": {
                  "range": {
                      "@timestamp": {
                       "from": "now-24h",
                                    "to": "now"
                    "query": {
                       "query_string": {
                        "query": "type:syslog"
You can also add and remove fields you'd like to see from the 'fields' section, like so:
"fields": ["user", "@timestamp"],
Hopefully this is enough to get you started - the API key can be used to query externally (from a different server, for instance).
It seems that this is misleading - I'll bring it up to our developers. Thank you!
Jesse
Twits Blog
