XI 5.2.5 - Hostgroup Commands no longer working
belvdr
Post by belvdr »
CentOS 7.2.1511 with NagiosXI 5.2.5
I noticed after the 5.2.4 or 5.2.5 upgrade, issuing commands against a hostgroup no longer work. Sorry I cannot be more clear about which patch caused it.
For example, if I select a hostgroup and issue "schedule downtime for all services" and check the Host box too, the command never gets issued. Further, I see nothing in /usr/local/nagiosxi/var/cmdsubsys.log.
EDIT: I found disabling notifications for services + hosts in the same manner above does work. It seems it's just the downtime action.
Re: XI 5.2.5 - Hostgroup Commands no longer working
This bug was verified/reported today (TASK ID 7854). It will be fixed in the next release of XI.
