Freshness check not working
michal.nastaly
Post by michal.nastaly »
I am using Nagios XI for my server side and NSClient++ for the client side. All the monitoring is configured to be passive checks. I have a freshness check set to 5 minutes. The problem i have is when i stop NSClient++ service on one of the the servers, Nagios XI does the freshness check but the message i receive is "OK: No data received yet." and the service is still flagged green even know it has been of for 24hrs.
How can i get this to work?
WillemDH
Re: Freshness check not working
Post by WillemDH »
Did you read through this: https://assets.nagios.com/downloads/nag ... hness.html
Can you post your service configuration pls?
Nagios XI 5.8.1
https://outsideit.net
hsmith
Agent Smith
Post by hsmith »
Thank you Willem.
@michal.nastaly, let us know. Thanks!
Former Nagios Employee.
me.
michal.nastaly
yes I have read that article and can see anything being wrong with my configuration,
This is the service configuration for NSClient service:
host_name N1-SERVELEC-TEST.hosting.servelec.local
service_description NSClient
use xiwizard_passive_service
servicegroups N1 SERVELEC TEST
max_check_attempts 5
check_interval 5
retry_interval 1
passive_checks_enabled 1
check_freshness 1
freshness_threshold 300
notification_interval 60
contacts nagiosadmin
contact_groups admins
_xiwizard passiveobject
register 1
michal.nastaly
Hi guys,
here is the Service settings that i have currently setup.
Anything wrong with it?
Use the "check_dummy" command to get whatever status/message you would like to receive. Example:
michal.nastaly
That seems to be doing the job! :)
Thank you
I am glad I could help! :)
