Check_Eximailqueue query returned no output!
rlinux57
Post by rlinux57 »
Check Locally:
./check_eximailqueue -w 3 -c 4
Mailqueue OK - 0 messages on queue
Check from NMS:
./check_nrpe -H IP_Address -c check_eximailqueue
[color=#FF0000]Mailqueue WARNING - query returned no output![/color]
cat /etc/sudoers:
Defaults:nagios !requiretty
%nagios         ALL=(ALL)       NOPASSWD: ALL
nagios          ALL=NOPASSWD:/usr/sbin/exim
nagios          ALL=(ALL) NOPASSWD:/usr/lib64/nagios/plugins/
Please find check_eximailqueue attachment:
check_eximailqueue.txt
(3.22 KiB) Downloaded 560 times
Re: Check_Eximailqueue query returned no output!
What is the result if you run the script on the client machine without NRPE?
rlinux57
Post by rlinux57 »
Ah - for whatever reason I assumed that was on the XI server. What user are you running it as in the above command, and what are the permissions on check_eximailqueue?
rlinux57
Post by rlinux57 »
It's nagios core.
ll /usr/lib64/nagios/plugins/check_eximailqueue
-rwxr-xr-x 1 root root 2417 Feb 29 08:01 /usr/lib64/nagios/plugins/check_eximailqueue*
What happens if you change the permissions to nagios:nagios? I realize you're trying to run this through sudo rules, but I believe permissions are the issue at this point.
Also - when you ran the command above, was that as root or nagios?
rlinux57
Post by rlinux57 »
I have changed it to nagios.nagios but still same issue.
I have run that command as root user.
Can you try running the command as nagios and post the result?
rlinux57
Post by rlinux57 »
How can i run command as nagios user whereas no shell given to nagios user ?
nagios:x:988:984::/var/spool/nagios:/sbin/nologin
ssax
Dreams In Code
Post by ssax »
In the script it lists exim as this:
/usr/local/exim/bin/exim
First find out which location is the right one and then you can adjust them to match.
Give that a try and let us know.
