Nrpe install error
ohlssrog
Nrpe install error
Post by ohlssrog »
Hi.
Nagios XI Version : 5.2.3
servername 2.6.32-358.2.1.el6.x86_64 x86_64
CentOS release 6.4 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/48.0.2564.116 Safari/537.36
Server Name: 10.
Server Address: 10.
Server Port: 80
Have add an centos 6.3 server with Linux server wizard (nrpe), all checker/Service are red-critical, ping checker is OK and green. Then install the nrpe agent follow the Installing_The_XI_Linux_Agent.pdf document i get
./fullinstall
Nagios Linux Agent Installer
This script will install the Nagios Linux Agent by executing all necessary
sub-scripts.
IMPORTANT: This script should only be used on a clean installed system:
RedHat Enterprise, CentOS, Fedora, or Oracle
OpenSUSE or SUSE Enterprise
Ubuntu or Debian
Do NOT use this on a system running any other distro or that
does not allow additional package installation.
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
Install.log output
Nagios Linux Agent Installation Log
DATE: Mon Feb 29 14:33:53 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
Configuring Repos...
epel-release RPM installed OK
Repos configured OK
Installing prerequisites...
Loaded plugins: fastestmirror, security
Determining fastest mirrors
Error: Cannot retrieve metalink for repository: epel. Please verify its path and try again
DATE: Mon Feb 29 14:41:54 CET 2016
DISTRO INFO:
CentOS
6.3
Have try to add our proxy IP:8080 to the yum.conf and ~./bash_profile file and add the above http address to hosts file. Havent restart network service after these changes..?
Done export http_proxy=http://IP:8080
Edit /etc/yum.repos.d/epel.repo with sslverify=false
Re: Nrpe install error
Can you run yum repolist and post the result back to us?
Obviously, your proxy is causing the issues... You can try installing ALL of the prerequisites manually on this machine - autoconf, gcc, glibc, libmcrypt-devel, make, openssl-devel, sudo, sysstat, xinetd, and bc.
Then run:
cd /tmp
wget https://assets.nagios.com/downloads/nagiosxi/agents/linux-nrpe-agent.tar.gz
tar zxvf linux-nrpe-agent.tar.gz
cd /tmp/linux-nrpe-agent
touch installed.repos
touch installed.prereqs
./fullinstall
ohlssrog
Post by ohlssrog »
[root@SLSVARC ~]# yum repolist
[root@SLSVARC linux-nrpe-agent]# touch installed.prereqs
[root@SLSVARC linux-nrpe-agent]# ./fullinstall
sub-scripts.
Ubuntu or Debian
Do you want to continue? [Y/n] y
Proceeding with installation...
Running './0-repos'...
Repos already configured - exiting.
RESULT=0
Running './1-prereqs'...
Prereqs already installed - skipping...
RESULT=0
Running './2-usersgroups'...
Adding users and groups...
groupadd: group 'nagios' already exists
useradd: user 'nagios' already exists
Users and groups added OK
RESULT=0
Running './3-services'...
/etc/services updated
RESULT=0
Running './4-firewall'...
iptables: Flushing firewall rules: [ OK ]
iptables: Setting chains to policy ACCEPT: filter [ OK ]
iptables: Unloading modules: [ OK ]
iptables: Applying firewall rules: [ OK ]
Firewall rules updated OK
RESULT=0
Running './A-subcomponents'...
SUB
NAGIOSPLUGINS
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to disable maintainer-specific portions of Makefiles... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/tmp/linux-nrpe-agent/subcomponents/nagiosplugins/nagios-plugins-2.0.3':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
real 0m1.273s
user 0m0.118s
sys 0m0.073s
make: *** No rule to make target `clean'. Stop.
real 0m0.002s
user 0m0.002s
sys 0m0.000s
make: *** No targets specified and no makefile found. Stop.
real 0m0.002s
user 0m0.001s
sys 0m0.000s
make: *** No rule to make target `install'. Stop.
real 0m0.002s
user 0m0.002s
sys 0m0.001s
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
The script that failed was: './A-subcomponents'
[root@SLSVARC linux-nrpe-agent]# cat ./install.log
DISTRO INFO:
CentOS
6.3
x86_64
Repos configured OK
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 14:42:29 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=6 ... 64&repo=os error was
14: PYCURL ERROR 6 - "Couldn't resolve host 'mirrorlist.centos.org'"
DATE: Mon Feb 29 14:53:19 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 14:54:05 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:14:48 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:16:30 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:18:45 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:19:08 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:41:28 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:44:12 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:59:06 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:59:27 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 16:00:07 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 14:03:14 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 14:09:40 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 14:34:01 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 14:52:04 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Mon Feb 29 15:12:36 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
DATE: Tue Mar 1 08:51:14 CET 2016
DISTRO INFO:
CentOS
6.3
x86_64
SUB
NAGIOSPLUGINS
real 0m1.273s
user 0m0.118s
sys 0m0.073s
real 0m0.002s
user 0m0.002s
sys 0m0.000s
real 0m0.002s
user 0m0.001s
sys 0m0.000s
real 0m0.002s
user 0m0.002s
sys 0m0.001s
I have tried to install the nrpe-2.13-nagios_plugins-1.4.15-CentOS_6-2.13.1_x86_64.rpm from OP5 site
https://www.op5.com/download-op5-monitor/agents/
But get follow error
rpm -Uvh nrpe-2.13-nagios_plugins-1.4.15-CentOS_6-2.13.1_x86_64.rpm
error: Failed dependencies:
mysql is needed by nrpe_nagiosplugins-2.13.1-release.x86_64
postgresql is needed by nrpe_nagiosplugins-2.13.1-release.x86_64
As @lmiltchev mentioned - this sounds to be proxy related. Can you verify the settings on your machine?
Also - what are the contents of this file? /etc/yum.repos.d/epel.repo
ohlssrog
Post by ohlssrog »
Can you please tell me where in centos i should configure proxyserver IP for internet access, linux is not my strongest skill
Requested output
name=Extra Packages for Enterprise Linux 6 - $basearch
#baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch
mirrorlist=https://mirrors.fedoraproject.org/metal ... =$basearch
failovermethod=priority
enabled=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-6
#sslverify=false
[epel-debuginfo]
name=Extra Packages for Enterprise Linux 6 - $basearch - Debug
#baseurl=http://download.fedoraproject.org/pub/e ... arch/debug
enabled=0
gpgcheck=1
[epel-source]
name=Extra Packages for Enterprise Linux 6 - $basearch - Source
#baseurl=http://download.fedoraproject.org/pub/epel/6/SRPMS
enabled=0
gpgcheck=1
Try configuring your proxy in the "/etc/yum.conf" and "/etc/wgetrc" as described in the KB article below:
https://support.nagios.com/kb/article.php?id=147
Let us know if this fixed your problem.
ohlssrog
Post by ohlssrog »
Hi
Still problem to install nrpe agent after edit these 2 files with proxy server.
installation output:
sub-scripts.
Ubuntu or Debian
RESULT=0
RESULT=0
Users/groups already configured - skipping.
RESULT=0
/etc/services already updated - skipping.
RESULT=0
Firewall rules already configured - skipping.
RESULT=0
SUB
NAGIOSPLUGINS
real 0m1.269s
user 0m0.123s
sys 0m0.064s
real 0m0.002s
user 0m0.001s
sys 0m0.000s
real 0m0.002s
user 0m0.001s
sys 0m0.000s
real 0m0.002s
user 0m0.002s
sys 0m0.001s
RESULT=1
INSTALLATION ERROR!
Can you run yum list and post the full output?
ohlssrog
Post by ohlssrog »
Requested output:
[root@SLSVARC ~]# yum list
[root@SLSVARC ~]#
