When I look at the MIBs under Admin -> Manage MIBs, they all have .txt extension.
I just imported a vendor MIB for my APC UPS and the MIB has .mib extension.
See screenshot. Is that an issue?
Imported MIBs Have .mib Extension. Is that Okay?
Re: Imported MIBs Have .mib Extension. Is that Okay?
As I understand it, the file extensions do not matter- I have seen .txt, .mib, or no extension at all in use.
I believe you are correct. Thanks!
Were there any other questions on the topic, or may I go ahead and lock this thread?
You can close it. Thanks.
Glad to help. I'll lock this thread now and feel free to open another should you require assistance with anything else.
