Socket Time Out error in the Amazon Ec2 Cloud Instance.
rahul5028
Post by rahul5028 »
I have created Nagios virtual Instance on Amazon Ec2 Cloud enviorment according to steps given below URL:
https://assets.nagios.com/downloads/nag ... -Cloud.pdf
After that I have Installed NSClient++ on windows Server the one which I have to monitor using Nagios EC2 Instance but its showing Socket Time out error for all monitored services in NagiosXI dashboard[ Note: Firewall turned off on windows server so there is no chance to block ports]
Re: Socket Time Out error in the Amazon Ec2 Cloud Instance.
Post by Box293 »
In the Amazon management interface you need to open the network ports for it to work.
rahul5028
Post by rahul5028 »
Following two ports already opened on AWS but still its giving socket timeout error:
Custom TCP Rule TCP 12489 0.0.0.0/0
Custom TCP Rule TCP 5666 0.0.0.0/0
Post by Box293 »
rahul5028 wrote:Following two ports already opened on AWS but still its giving socket timeout error:
Is this on the windows server in the EC2 instance?
Can you provide your nsclient.ini file from the Windows server.
rahul5028
Post by rahul5028 »
Just to give more info, I have open TCP ports on Nagios EC2 Instance to communicate with our local windows server(Note:This windows server is running locally in my company and only Nagios Instance running on Amazon AWS)
Also please find attached nsclient.ini file from the Windows server.
I don't see any listening ports in your config, what is the output of netstat -an | findstr "5666" on the windows machine?
Also - have you enabled the rules through Windows firewall?
rahul5028
Post by rahul5028 »
Here is the output of netstat -an | findstr "5666"(Refer attached screenshot).
Also my windows firewall turned-off , Do we still require to enable the rule through windows firewall.
Can you also run netstat -an | findstr "12489"?
Are your services attempting to use check_nrpe or check_nt?
rahul5028
Post by rahul5028 »
Here is the output of netstat -an | findstr "12489".
I'm not sure which one(check_nrpe,check_nt) my service attempting to use, Can you give some steps to check this?
Looks good regarding listening, I don't think your nsclient configuration is an issue.
To figure out what service you're using navigate to Configure -> Core Config Manager -> Click 'Services' on the left side, and search for the service in question.
You should see a page similar to this -
One more thing to check, from the nagios machine, on the CLI can you run nmap windowsip? (replace windowsip with the IP for the windows machine we're trying to check)
