how to use Naghostgroup.tar for host group for Google Map???
mohsin2011
Post by mohsin2011 »
hi,
how can we use host group in google map ? haw can i show polylines in google map ?? i have added Naghostgroup.tar how can i use it can any one please help me in making host group and showing it in google map icon connection with polyline ??
Hopes for your suggestions i have download this file from the link ,
http://exchange.nagios.org/directory/Ad ... ps/details
Thanks in Advance,
mguthrie
Re: how to use Naghostgroup.tar for host group for Google Ma
Post by mguthrie »
The link you referenced is a community addon for Nagios Core, and it's currently untested and not supported. The XI Component for Google Maps is located below, however it currently doesn't support polylines and hostgroups. We're currently working on adding a polylines feature to our current Google Maps component.
http://exchange.nagios.org/directory/Do ... XI/details
http://exchange.nagios.org/directory/Ad ... nt/details
http://exchange.nagios.org/directory/Ad ... et/details
mohsin2011
Thanks for your reply ... . i have used google map easily that is showing my hosts on map but i cant used polyline and host group in it ... . as you suggest me that its it was link for nagios core. Is there any way that i would use polyline and host group in my map using nagios xi either my own development ?? can you please give me your suggestions ?
or i can easily implement polyline and host group using Nagios Core by using link i mentioned in my post ?
Hopes for your suggestions soon i am deliberately waiting for your reply ...
Thanks in Advance,
