How to set Priority for Normal and Critical for Same OID
anguri.sudhakar
Post by anguri.sudhakar »
Hi ,
I have OID .1.3.6.1.4.1.19808.2.101.5 and i am receiving alarms up and down , But in Web Page it is showing Normal status OK.
please find the below syntax.
EVENT traceNotification .1.3.6.1.4.1.19808.2.101.5 "Status Events" Normal
FORMAT This notification is sent for trace notifications $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SnmpTrap" "$s" "$@" "$-*" "This notification is sent for trace notifications $*"
How do clear the Alarm change status to Critical..?
Please suggest me.
Sudhakar Anguri
hsmith
Agent Smith
Re: How to set Priority for Normal and Critical for Same OID
Post by hsmith »
Can you see if reading this thread helps you out?
https://support.nagios.com/forum/viewto ... 66#p164472
Former Nagios Employee.
me.
anguri.sudhakar
I am getting confusion ,Could please suggest me best link....
ssax
Dreams In Code
Post by ssax »
You need to change it to:
EVENT traceNotification .1.3.6.1.4.1.19808.2.101.5 "Status Events" Critical
Are you asking how you can have one trap do both Ok and Critical by parsing the traps?
Post by Box293 »
This tutorial goes into detail as to how the traps actually work from when they enter the server through to the Nagios services.
https://support.nagios.com/kb/article.php?id=77
There is a section that gets into the MATCH statement, which allows you to match an incoming value and based on that the state sent to nagios can be Normal or Critcal.
This allows multiple entries in snmptt.conf for the same OID.
anguri.sudhakar
You mention above question,Yes exactly i am looking for the above solution.Could you please suggest me.
below OID:
Can you post what make and model of the device that is sending the SNMP Trap?
Can you post the MIB file that the OID in your example came from so we can view it?
anguri.sudhakar
I have attached MIB file,
That MIB file is Rhino alarm which belongs open-cloud .
Sudhakar anguri
The MIB file didn't upload to this post, can you try to upload the file again?
Or can you provide a link to where you found the file?
anguri.sudhakar
Soryy... for inconvenience,
Now you can find the attachment.
