barman plugin
amicohen1
barman plugin
Post by amicohen1 »
hi,
whenver i use barman plugin, the NRPE respond with "NRPE: Unable to read output".
i was adding nagios to sudo without password for this script, and when i execute the command in command line (from root), it apears fine:
sudo /usr/lib/nagios/plugins/check-barman.rb -a backups_available -s angus -w 5 -c 6.
same thing happen also when i do it with: barman check --nagios .....
any idea ?
Ami
Re: barman plugin
What happens if you execute it as the nagios user (no sudo)?
Also - what are the permissions on the file? ls -l check-barman.rb
amicohen1
Re: barman plugin
Post by amicohen1 »
actually i moved to work directly on barman (barman check --nagios angus) and still same thing happening, also without sudo (when executing it directly with sudo account, its working fine)
sudo -U nagios -l
Matching Defaults entries for nagios on localhost:
env_reset, mail_badpass, secure_path=/usr/local/sbin\:/usr/local/bin\:/usr/sbin\:/usr/bin\:/sbin\:/bin
User nagios may run the following commands on localhost:
(root) NOPASSWD: /usr/lib/nagios/plugins/check-barman.rb, /usr/bin/barman
(ALL : ALL) ALL
-rwxr-xr-x 1 root root 851 Nov 16 11:51 /usr/bin/barman*
Re: barman plugin
Can you post how the command is setup in the nrpe,cfg file on the remote sysrem and how you are running the check on the Nagios system?
Re: barman plugin
Does adding the line below to sudors help?
nagios ALL=NOPASSWD: /usr/lib/nagios/plugins/check-barman.rb *
amicohen1
Re: barman plugin
Post by amicohen1 »
i tryed both options:
command[check_barman]=sudo /usr/bin/barman check --nagios angus
and
command[check_barman]=sudo /usr/lib/nagios/plugins/check-barman.rb -a backups_available -s angus -w 5 -c 6
(and also without the sudo).
i also tried the advise of adding * to sudoers file (nagios ALL=NOPASSWD:/usr/bin/barman * ), and same result
Re: barman plugin
On your remote system that the check is installed, can you run the following and post the output here?
su nagios
amicohen1
Re: barman plugin
Post by amicohen1 »
sorry for late response: when i logged in as root i get the following:
1 backups available
su -l nagios -c '/usr/lib/nagios/plugins/check-barman.rb -a backups_available -s angus -w 5 -c 6'
no output
amicohen1
Re: barman plugin
Post by amicohen1 »
found the problem...
nagios ALL=(root) NOPASSWD:/usr/bin/barman need to apear after the definitions of the groups. as described in: http://askubuntu.com/questions/504652/a ... oesnt-work
thanks alot for those who were trying to assist!!!
hsmith
Agent Smith
Re: barman plugin
Post by hsmith »
I'm glad you got it! Are we all right to close this topic?
Former Nagios Employee.
me.
