check_oracle_health Can't locate DBD/Oracle/Object.pm
radone
Post by radone »
First, I took this nagios server as a new employee and have no clue how do I contact the nagios XI support even though we own the license. So I am putting this in the general forum. I would appreciate if you can tell me how do I post in Nagios XI customer forum.
License Type: Host-Based
Number of Licensed Hosts: Unlimited
Maintenance Status: Current (Expires in 395 days on 2017-04-03)
Here is my issue:
I am unable to execute this plugin and getting the Can't locate DBD/Oracle/Object.pm in @INC error. Here is the issue in details:
[root@nagiosxxx xxxxxx]# uname -a
Linux nagiosxxx 2.6.32-431.el6.x86_64 #1 SMP Sun Nov 10 22:19:54 EST 2013 x86_64 x86_64 x86_64 GNU/Linux
[root@nagiosxxx xxxxxx]# echo $LD_LIBRARY_PATH
/usr/lib/oracle/11.2/client/lib
[root@nagiosxxx xxxxxx]# echo $ORACLE_HOME
[root@nagiosxxx xxxxxx]# sudo /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client/lib ORACLE_HOME=/usr/lib/oracle/11.2/client /usr/local/nagios/libexec/check_oracle_health --connect 'oracleserver.domain.com:1521/oraclesid' --username 'oracleuser' --password '************' --mode sql --name="select count\(\*\) from v\\\$session where status = "active"" --warning 50 --critical 200
CRITICAL - cannot connect to oracleserver.domain.com:1521/oraclesid. install_driver(Oracle) failed: Can't locate DBD/Oracle/Object.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /usr/lib64/perl5/DBD/Oracle.pm line 23.
BEGIN failed--compilation aborted at /usr/lib64/perl5/DBD/Oracle.pm line 23.
Compilation failed in require at (eval 19) line 3.
Perhaps a module that DBD::Oracle requires hasn't been fully installed
at /usr/local/nagios/libexec/check_oracle_health line 4755
[root@nagiosxxx xxxxxx]# cpan
Terminal does not support AddHistory.
cpan shell -- CPAN exploration and modules installation (v1.9402)
Enter 'h' for help.
cpan[1]> m DBD
CPAN: Storable loaded ok (v2.20)
Going to read '/root/.cpan/Metadata'
Database was generated on Fri, 04 Mar 2016 13:29:02 GMT
Module id = DBD
CPAN_USERID GMPASSOS (Graciliano Monteiro Passos <[email protected]>)
CPAN_VERSION 1.0
CPAN_FILE G/GM/GMPASSOS/HDB-1.05.tar.gz
INST_FILE (not installed)
cpan[2]> m DBI
Module id = DBI
CPAN_USERID TIMB (Tim Bunce <[email protected]>)
CPAN_VERSION 1.634
CPAN_FILE T/TI/TIMB/DBI-1.634.tar.gz
MANPAGE DBI - Database independent interface for Perl
INST_FILE /usr/local/lib64/perl5/DBI.pm
INST_VERSION 1.633
cpan[3]> m DBD::Oracle
Module id = DBD::Oracle
CPAN_USERID PYTHIAN (Pythian Remote DBA <pause-at-pythian.com>)
CPAN_VERSION 1.74
CPAN_FILE P/PY/PYTHIAN/DBD-Oracle-1.74.tar.gz
UPLOAD_DATE 2014-04-25
MANPAGE DBD::Oracle - Oracle database driver for the DBI module
INST_FILE /usr/lib64/perl5/DBD/Oracle.pm
INST_VERSION 1.74
cpan[4]>
Re: check_oracle_health Can't locate DBD/Oracle/Object.pm
Take a look at the installation instructions for the Oracle plugin. There are trouble shooting steps for that error.
If that doesn't work, can you run the following and post the output?
ls -lR /usr/lib64/perl5/DBD/
ls -lR /usr/local/lib64/perl5/DBD/
radone
Post by radone »
Thank you for your response. Looks like this machine already has the oracle client installed.
Here is the output of the command you requested:
/usr/lib64/perl5/DBD/:
total 444
-rw-r--r--. 1 root root 42882 Jan 31 2008 DBM.pm
-rw-r--r--. 1 root root 12323 Sep 27 2007 ExampleP.pm
-rw-r--r--. 1 root root 24211 Jun 5 2009 File.pm
drwxr-xr-x. 4 root root 4096 Feb 23 2015 Gofer
-rw-r--r--. 1 root root 48722 Dec 8 2009 Gofer.pm
drwxr-xr-x. 2 root root 4096 Feb 23 2015 mysql
-rw-r--r--. 1 root root 57165 Dec 9 2009 mysql.pm
-rw-r--r--. 1 root root 3761 Jun 14 2007 NullP.pm
-rw-r--r--. 1 root root 205226 Feb 24 2015 Oracle.pm
-rw-r--r--. 1 root root 29045 Oct 10 2007 Proxy.pm
-rw-r--r--. 1 root root 7983 Sep 26 2007 Sponge.pm
/usr/lib64/perl5/DBD/Gofer:
total 8
drwxr-xr-x. 2 root root 4096 Feb 23 2015 Policy
drwxr-xr-x. 2 root root 4096 Feb 23 2015 Transport
/usr/lib64/perl5/DBD/Gofer/Policy:
total 20
-rw-r--r--. 1 root root 5140 Oct 16 2007 Base.pm
-rw-r--r--. 1 root root 2148 Oct 16 2007 classic.pm
-rw-r--r--. 1 root root 1477 Oct 16 2007 pedantic.pm
-rw-r--r--. 1 root root 2639 Oct 16 2007 rush.pm
/usr/lib64/perl5/DBD/Gofer/Transport:
total 40
-rw-r--r--. 1 root root 12793 Feb 24 2009 Base.pm
-rw-r--r--. 1 root root 2814 Oct 16 2007 null.pm
-rw-r--r--. 1 root root 7343 Oct 16 2007 pipeone.pm
-rw-r--r--. 1 root root 9177 Mar 10 2008 stream.pm
/usr/lib64/perl5/DBD/mysql:
total 40
-rw-r--r--. 1 root root 16095 Sep 14 2009 GetInfo.pm
-rw-r--r--. 1 root root 22221 Sep 14 2009 INSTALL.pod
/usr/local/lib64/perl5/DBD/:
total 212
-r--r--r--. 1 root root 52096 Sep 8 2013 DBM.pm
-r--r--r--. 1 root root 12293 Nov 14 2013 ExampleP.pm
drwxr-xr-x. 2 root root 4096 Feb 24 2015 File
-r--r--r--. 1 root root 40711 Dec 11 2014 File.pm
drwxr-xr-x. 4 root root 4096 Feb 24 2015 Gofer
-r--r--r--. 1 root root 49070 Feb 5 2014 Gofer.pm
-r--r--r--. 1 root root 4461 Nov 14 2013 NullP.pm
-r--r--r--. 1 root root 29211 Sep 21 2014 Proxy.pm
-r--r--r--. 1 root root 7938 Jun 24 2013 Sponge.pm
/usr/local/lib64/perl5/DBD/File:
total 40
-r--r--r--. 1 root root 20598 Apr 4 2013 Developers.pod
-r--r--r--. 1 root root 5012 Apr 4 2013 HowTo.pod
-r--r--r--. 1 root root 5947 Apr 4 2013 Roadmap.pod
/usr/local/lib64/perl5/DBD/Gofer:
total 8
drwxr-xr-x. 2 root root 4096 Feb 24 2015 Policy
drwxr-xr-x. 2 root root 4096 Feb 24 2015 Transport
/usr/local/lib64/perl5/DBD/Gofer/Policy:
total 20
-r--r--r--. 1 root root 5089 Jun 24 2013 Base.pm
-r--r--r--. 1 root root 2106 Jun 24 2013 classic.pm
-r--r--r--. 1 root root 1435 Jun 24 2013 pedantic.pm
-r--r--r--. 1 root root 2597 Jun 24 2013 rush.pm
/usr/local/lib64/perl5/DBD/Gofer/Transport:
total 44
-r--r--r--. 1 root root 12755 Jun 24 2013 Base.pm
-r--r--r--. 1 root root 3356 Apr 4 2013 corostream.pm
-r--r--r--. 1 root root 2770 Jun 24 2013 null.pm
-r--r--r--. 1 root root 7299 Jun 24 2013 pipeone.pm
-r--r--r--. 1 root root 9248 Jun 24 2013 stream.pm
Thank you.
radone
Post by radone »
I saw that the oracle instalt client 12.1 was installed in this machine, although that provides the symlinks through 11.1. Anyway, following your documents above, I went ahead and remove all 3 oracle instant clients and reinstalled the latest verison of 11.2. And then downloaded the http://assets.nagios.com/downloads/gene ... install.sh and ran it. It did bunch of stuffs, and finally completed with following last two lines:
ORACLE_HOME=/usr/lib/oracle/11.2/client64
LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib
But even after than executing the check_oracle_health command displayed the same error as originally posted here:
One thing I am wondering is why there is no /usr/lib64/perl5/DBD/Oracle/Object.pm or /usr/local/lib64/perl5/DBD/Oracle/Object.pm file ! In fact no DBD/Oracle directory.
Thanks.
Most probably this is due to the Perl module not being installed properly. The issue is described in our documentation:
To remedy this problem, execute the following from the command line:
export ORACLE_HOME=/usr/lib/oracle/11.2/client64
export LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib
cpan -i DBD::Oracle
radone
Post by radone »
Following straight through that docs did not work but certainly pointed me to the right direction.
I am not sure how the Oracle.pm file was brought there in /usr/local/lib64/perl5/DBD/... I can see that Oracle:DBD alyeady installed when I used the cpan to install the module. But as you said, Oracle:DBD might not have installed correctly. So I had to rename that file Oracle.pm to something else and then removed the oracle instant clients. Then installed the oracle instant client again, and then installed the Oracle::DBD from cpan. That resolved the issue. I can now see that DBD/Oracle/Object.pm file. So it seems true that Oracle:DBD might not have installed properly before, or previous admin might just have copied the Oracle.pm file instead of properly installing the module.
The issue is now resolved. Thanks.
I would appreciate if you can tell me how do I post it to the nagioxxi in Customer Support if I have any future issues or questions. We are the customer of Nagios and we have the "Nagios XI Unlimited Node Renewal -1 Year Email and Support and Maintenance" and also "Nagios XI Enterprise License Add-on Renewal, 1 Years Maintenance". I have the account number too. Just not sure how do I get access there.
Thanks.
I am glad I could help! :)
Please contact our sales team at [email protected]. They will be able to grant you access to the Customer only support forum. Thanks!
