Extract Multiple Queries
rlinux57
Post by rlinux57 »
How to extract multiple queries at a time ?
jolson
Attack Rabbit
Re: Extract Multiple Queries
Post by jolson »
Are you looking for a way to use the API to run multiple queries in one command? If so, try the following:
curl -XPOST "http://localhost:9200/_search?pretty" -d'
    "fields": ["user", "message", "type"],
    "query": {
    "bool": {
      "should": [
        { "match": { "message":  "Failed" }},
        { "match": { "message": "Something Else"   }}
Explanation: https://www.elastic.co/guide/en/elastic ... rings.html
Twits Blog
