Call Custom SQL Script
scunningham99
Post by scunningham99 »
HI
Please can someone tell me how to call a custom script? I need to call a custom script and return text values ?
for example
SQL> select release_name from fnd_product_groups:
returns 12.1.3.
I need to display the value?
Re: Call Custom SQL Script
You can use NSClient++ and Nagios XI to call a custom script. Place the script in the NSClient++ scripts' directory, define your command in the "nsclient.ini" file, restart NSClient++ service, and test your check from the command line.
Here's a simple example of defining a command in nsclient.ini, and calling the script from Nagios XI:
In "nsclient.ini"
check_process_memory = cmd /c echo scripts\process_mem.ps1; exit $LastExitCode | powershell.exe -command -
In Nagios XI:
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_process_memory
0.62
